Bob
Chip Hindes wrote:If you skip the second set of brakes, make sure the brakes are on the rear axle. Otherwise, due to the geometry of the tandem axle system, braking can cause wheel hop on the trailer. A good explanation of why this happens used to be on the Champion website; if you can't find it I can explain.
IMO once you've decided on the second axle, the additional cost to add the second set of brakes is well justified.
Not sure where that comes from. It's been obvious for years that Roger sets the axle position based on no or at most a modest outboard, in order to keep both the tongue weight and tow weight down, so he can then claim the boat can be towed by a (insert "Taurus" or other inadequate tow vehicle model here).Frank wrote: Roger sets the axle position to account for a reasonably sized outboard, plus the boat & some gear.
Somwhat contradictory. If you can only tow with empty fuel tanks or you have to move all the movable gear forward, then by definition you have a problem with tongue weight. You can't always guarantee the tanks will be empty when you load up the boat; and at some point, you'll either fill them on the trailer or be prepared to pay 30% more for gas at the marina fuel dock. Then the fuel tanks are either in the lockers where they belong, or, or as I had to do once before I solved the tongue weight problem, moved up to the v-berth. Didn't want to do it, had no choice. By the same token, it is nice to be able to load the boat in the fashion in which it will be sailed, rather than have to move stuff forward to tow, then back where it belongs for sailing/motoring or storage. Not having to move stuff around is also on reason I got to the point I could be sailing within 20 minutes of arrival, on the road within 30 minutes of docking.Frank wrote: I never carry fuel in the lockers during travel, and load all gear toward the bow ... no problems here with tongue wt. Mine was checked at a Mayflower yard ... about 8 percent.
Unfortunately (after lo these many years) Chip remains content to rely on anecdotal rules of thumb for travel trailers, rather than doing some research on the larger industry, especially the boat trailering industry.Chip Hindes wrote: . . . Finally, after lo these many years, there's still not one person other than Frank (?~!)
who thinks 8% is adequate tongue weight. It's 10% minimum, always has been, always will be.
