OEM trailer axle failure
beechkingd
Post by beechkingd » Tue Jul 16, 2019 4:21 pm
My `95 X trailer axle end cap plates rusted from the inside and snapped after hitting a pot hole. The actual axle beam was in great shape, but the plate that the trailer spindle was welded onto rusted from the inside. I think it was open from the bottom and was basically 3/4" inboard of the brake plate. It's not a place I would have thought to look at. Last year I'd done a tap test on many areas of the trailer and didn't see anything that scared me, I totally missed this one.
upload images
Thankfully I was going slow around a tight corner, the fender held the weight and stopped it from doing anything more than cosmetic damage to the hull. I was able to get a new axle custom made by Champion trailers. It took for ever for them to actually ship out though so if you do order from them I would call frequently to check progress.
https://www.championtrailers.com/galvan ... e-over-85/
Hub face 88" Spring center 68"
The original axle was a 2X3 drop axle but the original spindle wasn't mounted on top of the axle tube so I went with the 2X2 tube since they weld it on top. It fit perfectly, the only thing lacking was brake line loops which I ended up attaching with some ziptie standoffs.
The other issue I had was the brake hose on my trailer rolled the threads when I unscrewed it from the fitting. It was a Male/Female 1/8" brake hose with standard 3/8" 24 threads and it was 24" long, should be easy to find right??? I could not find one locally but after scouring a few websites I was able to find a 20" long one that went on a 1971 Ford F100 that had the right fittings on it and one of the local chain parts stores had one in stock.
Re: OEM trailer axle failure
Post by Jimmyt » Wed Jul 17, 2019 7:39 pm
Yikes! Glad you didn't have major damage!
BestMACSailor
Post by BestMACSailor » Mon Jul 22, 2019 6:10 pm
The OEM trailer seems to be sub standard
beechkingd
Post by beechkingd » Tue Jul 23, 2019 3:21 pm
It's 24 years old, so it certainly doesn't owe me anything, it could have been made better that's for sure. Of all the previous issues I've read about I hadn't read about this one.
