HOW FAST IS YOUR MAC ?
irayone
Post by irayone » Tue May 26, 2009 11:59 am
Just want to get an idea of how fast your boats are ???
1. MOTOR
2. YEAR
3. TOP SPEED BALLAST FULL
4. RPM
5. KNOTS
6. BALLAST EMPTY
7. RPM
8. KNOTS
9. PROP SIZE
c130king
Re: HOW FAST IS YOUR MAC ?
Post by c130king » Tue May 26, 2009 12:16 pm
irayone wrote:Just want to get an idea of how fast your boats are ???
1. MOTOR -- Mercury 40 HP 2 Stroke (with Powerthruster)
2. YEAR -- 2005
3. TOP SPEED BALLAST FULL -- 11-12 Kts in smooth water
4. RPM -- 5000
5. KNOTS
6. BALLAST EMPTY -- 16 Kts
7. RPM -- 5200
8. KNOTS
9. PROP SIZE -- 8 x 12
David Mellon
Post by David Mellon » Tue May 26, 2009 3:43 pm
1. MOTOR Evinrude ETEC 60
2. YEAR '06
3. TOP SPEED BALLAST FULL 17 MPH
4. RPM 5300
5. KNOTS
6. BALLAST EMPTY 20 MPH
7. RPM 5800
8. KNOTS
9. PROP SIZE[/quote]
jaguar496
Location: MESIC, NC, '08 26M 40hp suzuki "THE RESTLESS TWO" MACM2023L708
Post by jaguar496 » Tue May 26, 2009 5:02 pm
[quote="irayone"]Just want to get an idea of how fast your boats are ???
1. MOTOR SUZUKI 40 HP 4 STROKE
2. YEAR 2008
4. RPM 5900
5. KNOTS 13KTS
6. BALLAST EMPTY
7. RPM 5900
8. KNOTS 15-16KTS
9. PROP SIZE9X12.5
Duane Dunn, Allegro
Post by Duane Dunn, Allegro » Tue May 26, 2009 5:20 pm
1. MOTOR Tohatsu TLDI 90
2. YEAR (Boat) 1996 X, (Motor) 2005
4. RPM 5,500
5. KNOTS 18 knots (20.7 mph)
6. BALLAST EMPTY
7. RPM 5,600
8. KNOTS 22 knots (25.3 mph)
9. PROP SIZE 14" x 11" factory aluminum
Pretty good speed considering I have a very heavily loaded boat setup for extended cruising with my family on board. In general I never run WOT with ballast. If I want to go fast or far under power I always dump any ballast. I take her up to around 4,500 RPM, this gets me in the mid 14 knots for speed with a nice high bow, when the speed peaks out in the upper 16's I know the tank is empty.
John Christian
Location: 2007 26M "Pamela Jean" White Hull#1862, Suzkuki DF 70, Brest Bay Marina, Lake Erie
Post by John Christian » Tue May 26, 2009 5:56 pm
1. MOTOR Suzuki DF 70
2. YEAR 2007
3. TOP SPEED BALLAST FULL 16 - 17 Knots in calm lake
4. RPM 5000
5. KNOTS
6. BALLAST EMPTY 19 - 20 Knots
7. RPM 5400
8. KNOTS
9. PROP SIZE 14 x 11
Bottom Paint
Hardcrab
Post by Hardcrab » Wed May 27, 2009 3:53 pm
I've had our M at least to 75 mph on my first trip up I-15 from So Cal.
It was uphill to!
Handled well as I recall.
RPM's about 3400, downshifted to fourth gear.
:wink: :D :P :) 8)
SkiDeep2001
Post by SkiDeep2001 » Wed May 27, 2009 4:20 pm
hardcrab, :o hope you have your boat strapped down. 1st time driving truck/boat (17' Glaspar with 90Merc) on the Cariboo hiway in BC just south of 100 mile house and dad was asleep,I'm 15 so had it up to 70+ mph not kph and boat was loaded with gear and when I looked in mirror it was floating above the trailer, swaying side to side. :? We forgot to strap it down and I got it slowed and pulled over before anything happened. If you don't have one, buy a strap. It might save you a big headache in future. :wink:
Steve
Post by Steve » Sun Jul 05, 2009 6:25 pm
1. MOTOR: 50hp/4str. Yamaha
2. YEAR: '99
3. TOP SPEED BALLAST FULL: 15 mph
4. RPM
5. KNOTS
6. BALLAST EMPTY: 19.6 mph
7. RPM: around 5000
8. KNOTS
9. PROP SIZE: 3 fin stock that came with it
rwmiller56
Location: SF Bay Area, CA; 2005 MacGregor 26M, "Lazy Lightning", 2015 E-Tec 60 HP
Post by rwmiller56 » Mon Jul 06, 2009 8:42 am
1. MOTOR
Johnson 4S 50 HP
2. YEAR
2005
12 kts
4. RPM
5800
5. KNOTS
6. BALLAST EMPTY
Haven't tried yet.
7. RPM
8. KNOTS
9. PROP SIZE
PatrickS
Post by PatrickS » Mon Jul 06, 2009 10:48 pm
1. MOTOR
2007 Mercury 50ELPTO, 50hp 2stroke
2. YEAR [AND MODEL]
2001 26X
11 knots
4. RPM
5600
5. KNOTS
6.[TOP SPEED]BALLAST EMPTY
16 knots
7. RPM
5600
8. KNOTS
9. PROP SIZE
13x10.5 IIRC
One bit of information missing that would be relevant:
10. DEGREE OF ENHANCEMENTS / GEAR (Pick one):
(a) Stock boat, with no little to no major enhancements and minimal gear.
(b) Relatively stock boat with some enhancements (some elecronics, a stove, etc.) and gear.
(c) Moderately enhanced boat with more comprehensive gear.
(d) Significantly enhanced boat with alot of gear. -> D
FWIW my 26X is equipped for longer term cruising (even liveaboard) with alot of gear, and inspected/certified to Finnish class 2 (coastal) level, with lots of required safety gear, plus lots of convenience enhancements such as chartplotter, autopilot, two VHF, stereo, stove, fridge, paraffin heater, running water, builtin water tank, 24gal fuel tanks, 220AH AGM house bank, shorepower, etc. so I'm glad to still be able to hit 15 knots just by my lonesome -- though I almost never run at WOT, tending to mostly sail or motorsail.
So a realistic comparison would need to take into consideration how much extra a given boat has (I dimly recall the day when my X was stock and the kids wakeboarded behind it... alas, no more... I wonder if we need a MMI formula (Mac Mass Index, a'la BMI, Body Mass Index) to guage how much "extra" our boats have ;-)
Post by Russ » Tue Jul 07, 2009 1:23 pm
1. MOTOR Suzuki 70 4 stroke
2. YEAR 2008
3. TOP SPEED BALLAST FULL 15mph
4. RPM 4200
5. KNOTS
6. BALLAST EMPTY 19 mph
7. RPM ??
8. KNOTS
9. PROP SIZE ?? prop BWY installed.
Elevation 5500 feet fresh water no bottom paint. These are factors.
Don T
Post by Don T » Tue Jul 07, 2009 1:46 pm
1. MOTOR - Tohatsu 50 2 stroke carbs
2. YEAR 1995
4. RPM 5200
5. KNOTS 12
6. BALLAST EMPTY
7. RPM 5600
8. KNOTS 15
9. PROP SIZE 12 X 11.5 (BWY special)
Like Duane, I never run more than hull speed with the ballast full. My boat has lots of added weight with mods and equipment for long cruises. I'll have to verify my two prop's pitches cuz' it's been a while since I looked at them.
Paul L
Post by Paul L » Tue Jul 07, 2009 9:31 pm
2. YEAR 2005
4. RPM 5000
5. KNOTS 14
6. BALLAST EMPTY Never tried
7. RPM
8. KNOTS
9. PROP SIZE 3x13x13.5
Suzuki manual says correct prop size for a given hull should result in 5700 rpm on the DF 70, but I can't get that with this BWY selected prop. Maybe I could with less load & balast.
Billy
Post by Billy » Wed Jul 08, 2009 5:06 am
1. MOTOR Suzuki DF140 (2002)
2. YEAR 2001
4. RPM 6000
5. KNOTS ) 25 kts. (29 mph) (moderately loaded)
6. BALLAST EMPTY
7. RPM 6300
8. KNOTS 31.2 (36 mph) (3 ppl)
9. PROP SIZE 18 pitch
Manual states operating rpm 5600-6200---but who counting :D Speed actually determined by conditions on water.
