Backstay and Cars?
Backstay and Cars?
Post by dlandersson » Sat Mar 16, 2019 2:24 pm
I just sat in on a very interesting sailing seminar talk in Michigan City.
Apparently the backstay can be used to adjust tension on the forestay - I've been pretty much ignoring the backstay. :cry:
Apparently moving the port/starboard Cars forward and back can help adjust the Jib/Genoa? - I've been pretty much leaving them in one spot for 8+ years.
Re: Backstay and Cars?
Post by Tomfoolery » Sat Mar 16, 2019 3:12 pm
Moving the cars forward takes some of the twist out of the jib/genoa. Think of it like stepping on the accelerator - forward is more power, back is less.
Post by dlandersson » Sat Mar 16, 2019 3:29 pm
Back also allows you to sail closer to the wind. :wink:
Tomfoolery wrote:Moving the cars forward takes some of the twist out of the jib/genoa. Think of it like stepping on the accelerator - forward is more power, back is less.
Herschel
Post by Herschel » Sun Mar 17, 2019 7:23 pm
Back in my racing days, I was taught that you moved the cars back the stronger the wind, and correspondingly, as the wind slacked off, the cars were rigged farther forward. All about getting the best shape for the jib given the wind strength. Changes were made, if needed, when tacking, if at all possible.
Post by dlandersson » Mon Mar 18, 2019 4:49 am
The seminar was primarily about racing with a crew and getting every possible inch of speed/performance - not something X's are generally noted for. :P
Alexis
Post by Alexis » Wed May 01, 2019 10:34 am
For lake sailors: I assume that backing up the cars could allow to catch the wind higher above the water level, if the flow of air is broken by the shores. Does that seem correct?
Post by dlandersson » Thu May 02, 2019 1:57 am
No, nothing was said about "catching wind higher above water level" 8)
Post by Tomfoolery » Fri May 03, 2019 3:48 pm
If anything, moving the cars back would allow more twist in the sail, spilling air from the top. The opposite of what you’d want if wind is sparse.
