short table for 26M
Moderators: kmclemore, Catigale, Hamin' X, beene, NiceAft
cestlavie
short table for 26M
Post by cestlavie » Mon Aug 21, 2017 5:04 pm
2003 26M with the sideways galley up against head, adding a shorter table that can be walked around and not too much of hassle to leave up.
2 pieces of 450mm x 180mm pine glued together, 25mm pipe from an old trampoline net holder,10mm bolt, flat steel, some cold galv spray paint and my dodgey welds
Soldering iron to etch image, 2 coats of varnish. next will be folding cockpit table and mount that will use the mast holder pipe thru the steering pedestal
