Motor well scupper.
Ixneigh
Motor well scupper.
Post by Ixneigh » Tue Aug 06, 2019 2:28 pm
Tired of that motor well drain plugging up, need to do something about the plumbing, the sink line and the scupper line all going to one outlet. And poorly.
Option 1 install new through hull just for outboard well. Replace drain with a standard through hull and use good hose to connect with double clamps.
Option 2 use larger throughhull, and continue to tee both sink and scupper drain to it. Locating a proper seaworthy T junction might be an issue. None at west marine. Only plastic type. Upgrade plumbing as needed.
I looked at option 3, cutting a drain right through the transom, but didn’t like that as it was too close to the motor mounts.
kurz
Re: Motor well scupper.
Post by kurz » Wed Aug 07, 2019 3:01 am
What is exactely your problem/concern with the factory stile?
As long as you don't come 3 inch higher obove water line it does not look as an improvement.
What do you want to be better after the mod?
Jimmyt
Post by Jimmyt » Tue Aug 13, 2019 6:11 am
Stock drain is too small. A dead June bug will clog it. Anxious to see what he does on this. :)
Wayne nicol
Post by Wayne nicol » Wed Aug 14, 2019 9:02 am
i had the same problem, even very small debris would block the factory setup.
and if you tried to back flush it with a hose, it would take the path of least resistance- and blow back into the sink
i put a thru hull in the well, and put a new thru hull next to the sink one on the transom, dedicated solely to the motor well. decent 3/4" hose and double ss clamps both ends.
i also then upgraded the sink drain with the same, smooth 3/4" hose, got rid of the corrugated one that trapped residue like a gold sluice box.
never had to touch it since
Ixneigh
Post by Ixneigh » Thu Oct 03, 2019 10:04 pm
I ended up locating some of the hardware at a marine 2nd hand place nearby much more economically than buying it from West Marine. I found some 11/4 inch matched through hull fittings in bronze so I installed those. The hull outlet is now on the other side of the engine from where the sink outlet is. I replaced the sink outlet with a slightly larger bronze fitting as well. I used an elbow fitting on the tail end of the throughhull fitting in the motor well, because the heavier tubing I used seemed to need it to have a fair run in a gentle curve to the other one. Seems to drain fine now. Dog hair, leaves, bugs no problem. Much more shipshape than the original setup which was abysmal. Next year I may replace the galley sink with a stainless one then I don’t plan on any more plumbing jobs for a while.
Ixnay
