Sink faucet
- Sloop John B
Sink faucet
I have another ding bat question. How do you get the sink faucet to go?
The big wiggly water bag is near full of water. There’s an air pocket on the top. The red cap has a “switch” for open and close. It’s open. The plastic faucet doesn't appear to be plugged. The lever swings back and forth 180 degrees. Is there some way of priming this sucker?
Re: Sink faucet
The faucet seals might be dried up. That bag thingy is pretty ridiculous IMO.
Prime....yea, seems like I had to squeeze the bag while pumping. 2 man operation. Soon after I removed the pump and installed pressure pump. Sigh
- opie
- Location: Wilmington NC, BF50A Honda, 1999 MacX, "Marin"
Re: Sink faucet
It is relatively easy to take apart. After doing so, wipe vaseline on the parts including the little rolling ball bearing. Since you are not drinking this water anyway, don't worry about the vaseline getting in the discharge. Very little will anyway. Walaaaa! You have a valve that can prime now.
Another problem that may occur is a small leak from the operating arm that leaks onto the sink area. For this repair, you have to pry out the operating arm (it is not easy, but it comes out) then buy an o-ring that fits at your hardware store and replace the o-ring. Wallaa^2!
Be aware that if your water tube sits snuggly on the bottom of the flexible water container, it will not pump and the operating arm could break if you try to pump water while tube is sucking on the plastic bottom rather than the water itself.
Re: Sink faucet
Wondered the same thing? could only get it work by submerging the pickup/cap, typically then leaked - life's too short so I caved in and wired in a cheap caravan pump/switched tap (40$) simply pushed in the open reliant bag. Full, never spills even at 35 odd deg heel.
Good to see you still around, read some humorous posts of yours (thumbup)
http://s17.photobucket.com/user/light_m ... sort=4&o=0
- Wind Chime
Re: Sink faucet
We turn the bag upside down so the opening end where the hose attaches and water comes out is pointed down, gravity seems to always get is started and keep it going.
We added a 13 gallon pressure water system with 2-stage filter for the galley sink, and use a separate 5 gallon collapsible bag system in the head but had to replace the factory faucet a few years back.
- wbpenney
- Location: Cary, NC - 'Boom Boom ll' 08 26M 90HP E-TEC http://boomboom2.blogspot.com/
Re: Sink faucet
The water bag has to be turned so that the outlet is on the bottom, otherwise the pump just sucks air. The only other way is to squeeze all the air out of the bag, but usually air will creep back into the bag if the bag is too rigid.
- Dimitri-2000X-Tampa
Re: Sink faucet
One of the first and probably THE best mods I did was to get rid of that original system and add a 25 gallon bladder pressure water system (using inexpensive RV pump and pressure tank and my old kitchen faucet). Its definitely nice to always have pressurized water, and I can shower with it or flush the outboard with it if I feel like it (with the hose attachment that Y valves off of it).
- Sloop John B
Re: Sink faucet
Thanks for the advice. Opie said the faucet could be taken apart. Didn't know that. There's a plunger type piston that works up and down. This one was frozen over time. Needed a little sanding and Vaseline and it's good as new.
- DaveB
Re: Sink faucet
I guess I am missing something. I thought it was a Urnal as the bowl was big enough to pi$$ in a seaway. Also saves room in the 5 Gal. porta Potty to do #2.
I use main sink for dishes and cleanups.
Ya got to be a Midgit to use the Head Sink to wash and use.
I use a 14 Gal. Inflatable Plato under the Galley.
Use the head Sink as a urnal and open air vent on your 5 gal. tank.
Makes trips longer without pump outs.
Sloop John B wrote:I have another ding bat question. How do you get the sink faucet to go?
Re: Sink faucet
You must have great aim. Especially in a bouncing sea.DaveB wrote:I guess I am missing something. I thought it was a Urnal as the bowl was big enough to pi$$ in a seaway. Also saves room in the 5 Gal. porta Potty to do #2.
- DaveB
Re: Sink faucet
One hand on quart container, other on private parts, than down the hatch. KEY: Brace yourself using your head on liner.
You are not going far in the restrictions compartment of a Mac. Head.
To be honest, at 237 lbs and 6 ft. I need to keep door open to fit in this closet.
Can you imagine on a Mac M....whoosh. Craped my pants trying to get them off in that pee hole pot of The M. Injured with back pains stooping.
Reather deal with the Closet of the MacX.
Some designers are taller than Rodgers 5-6 height.
RussMT wrote:You must have great aim. Especially in a bouncing sea.DaveB wrote:I guess I am missing something. I thought it was a Urnal as the bowl was big enough to pi$$ in a seaway. Also saves room in the 5 Gal. porta Potty to do #2.
