I wasn't trying to tack.
My boat simply moved into the wind all by herself - and when I tried to "go with the flow" - she would not "cross over either". I was some kind of "stuck".
Hamin' X wrote:Does sound like your were hove-to. Were the sails flogging?
DaveC426913 wrote:Sorry, what does this mean? You couldn't head up past 30? Or couldn't fall off past 30?dlandersson wrote:... starts turning inside 30 degrees winward. I can't turn her back, so I simply tack over - no go. No matter what I do, my boat won't turn past 30 degrees, and is often "in irons"...
That didn't actually answer my question.dlandersson wrote:Could not get her past 30 - nor would she let me turn from port to starboard or reverse.
DaveC426913 wrote:DaveC426913 wrote:Sorry, what does this mean? You couldn't head up past 30? Or couldn't fall off past 30?dlandersson wrote:... starts turning inside 30 degrees winward. I can't turn her back, so I simply tack over - no go. No matter what I do, my boat won't turn past 30 degrees, and is often "in irons"...That didn't actually answer my question.dlandersson wrote:Could not get her past 30 - nor would she let me turn from port to starboard or reverse.![]()
I'm going to assume you mean you couldn't fall off below 30.
To me, that sounds like rounding up. When I'm trying to maintain a course into the wind and she keeps rounding up, I call that 'scalloping'.
I found the problem was too much sail. The main is pushing you up into the wind. You find yourself in irons a lot and can't steer. Then the moment the sails fill, you heel and round up again.
As Waybe and nicol are suggesting, best thing to do is reef the main, But also, whenever you feel the speed picking up, and you're about to round up, ease the main, spill some wind. You may be able to stave off a round up.
Right. And you also said you were over at 20 degrees.dlandersson wrote: My boat would move from close hauled (port or starboard) to "in irons" despite anything I could do. (Did not change the main in any way)
DaveC426913 wrote:Right. And you also said you were over at 20 degrees.dlandersson wrote: My boat would move from close hauled (port or starboard) to "in irons" despite anything I could do. (Did not change the main in any way)
So your overpowered main is causing you to round up.
Tack without easing the jib sheets so the jib stays backwinded, and once you're in irons, hard over the helm the opposite direction and keep the rudders hard over. Easy.sirlandsalot wrote:So much to learn, I took my boat out a few times this summer, without my crew. I played with too much sail in too much wind. I got to it hold over 30 degrees, efficient no, but a lot of fun. I too found my boat round up without a reef in the main. I actually sailed a lot with the main reefed. I also had the horrifying experience of too much jib out, and un-commanded jibing! Sweet lord I scared myself, everything upside down below!
All in all, a good summer and learned a lot and pushed the boat hard. Now when I am out with my family, I feel much more confident to keep things pleasant.
One question? How do you heave too in a Mac?
Actually quite similar, in heavier winds. If you completely furl the headsail and then harden up the mainsheet so the boom is on the centerline, the boat will remain in irons basically hove-to. It's an even more reliable hove-to than using the headsail, because you can actually pull the rudders up and it will just stay that way. While I've not tested it in a storm, this is likely the best storm tactic for an X or M because it keeps the bow pointed directly at oncoming waves and will preserve the rudders and headsail, so even if your mainsail is flogged to death in the storm, you still have enough sail and boards to get home.darrenj wrote:I once tried to sail with just the main sail (head sail furled) on my X .... I was stuck in irons the whole time. I found that I had to use the headsail to pull the bow out of irons while leaving the mainsail slack until I got up some speed. I now do that to some degree on each tack as it speeds up the tack so that I don't lose as much speed. I think the M boats behave quite differently under main sail alone.
It sounds like you would benefit greatly from a single-line reefing system. One line, operated from the cockpit. Look it up.Sloop John B wrote:The real solution is to reef the main.
Not too much of a problem in my youth. Now in my mid-seventies my balance on a scale of 1 to 10 is 1.9. Heading into the wind to allow the main to drop causes the boom to flail back and forth like an ingenious device on “wipe out”. When moving about the boat I have to have hold of something and I can’t make it for sure from the cockpit to a stay in rough seas.
