Lubrication point on axle?
Jwnj
Post by Jwnj » Sat Aug 24, 2019 10:46 am
Guys, does anyone know what this is on the inside of the hub/brake assembly? Is it another point to lubricate with marine lube or its something for brake bleeding/filling? (1998 26x steel trailer) It looks to be very close to brake line. Asking because i lubed the normal way and still have noise when driving so before i take the whole thing apart would be good to know
Jwnj
Re: Lubrication point on axle?
Post by Jwnj » Sat Aug 24, 2019 10:49 am
1st Sail
Post by 1st Sail » Sat Aug 24, 2019 1:59 pm
FYI it appears the link is not set to public access as it require a 'request access".
Hamin' X
Post by Hamin' X » Sat Aug 24, 2019 3:24 pm
The fitting that you are referring to is the brake bleeder valve. The only lube points on the axle/hubs are the wheel bearings.
Jwnj
Post by Jwnj » Tue Aug 27, 2019 7:45 am
I unlocked the image link. Pretty sure its a bleeder for surge brake just didnt realize the surge brake was such a complex system but i guess a brake is a brake. Anyone know the weight at which surge brakes are required?
Jwnj
Post by Jwnj » Tue Aug 27, 2019 7:46 am
Thanks Rich juat saw your reply
Post by Tomfoolery » Tue Aug 27, 2019 11:02 am
The threshold for brakes varies by State. Even the number of trailer axles that require brakes, when there are two or more axles, varies by State - NY only requires brakes on one axle when brakes are required, but I believe Maryland requires them on all axles, for instance.
I don't believe any State differentiates between electric, electro-hydraulic, or hydraulic (surge) brakes. Not any more, at least.
Here's just one of many sites that list brake requirements by State. The frequent mention of "independent" brakes is a throw-back to where surge brakes wouldn't be allowed in some instances. The Federal DOT requirements and the State requirements have since been aligned so surge brakes are allowed everywhere. It was a problem for places like U-Haul, where they supply trailers with surge brakes that can work on any tow vehicle, but they couldn't be independently controlled from the cab like in a tractor-trailer (trolley brake lever) or a tow vehicle pulling a trailer with straight electric brakes (brake controller in the cab). I don't remember the details any more, but those requirements, which almost certainly were intended for semi-trailers with air brakes originally, have been reconciled not that long ago.
https://drivinglaws.aaa.com/tag/trailer-brakes/
