What line do you use for MRS?
DaveC426913
Post by DaveC426913 » Sat Jun 27, 2020 4:26 pm
I used to go for the 4:1 boom vang, but have started using the 4:1 mainsheet because it has a very convenient built-in cleat to hold the mast where I want it while I run back to disentangle shrouds n such.
Then one day, in the middle of the season, I decided the main sheet was far longer than it needed to be, and just piled up in the bucket. So I set the sail out to full broad reach, gave it a few extra feet, and cut off the rest - maybe 12 feet or so.
Flash forward to end-of-season, and I used the mainsheet line to lower the mast - until it got down to about 30 degrees - and I ran out of line. Slipped right through my fingers, and the mast whammed down on my bimini frame.
Oops.
Re: What line do you use for MRS?
Post by Tomfoolery » Sun Jun 28, 2020 5:01 am
Oops.
I use a dedicated 5:1 setup with larger ball bearing blocks, and the rope clutch on the cabin roof that’s used for the main sheet.
With a stopper knot in the end, just in case. :wink:
Tom
Be seeing you . . .
Post by Jimmyt » Sun Jun 28, 2020 6:46 am
Yikes! Glad no one was hurt!
26M, Etec 60, roller Genoa, roller main
Post by Catigale » Sun Jun 28, 2020 9:36 am
I let my 6 foot college athlete lower my mast with a dock line, usually with one hand while she talks on the phone
DaveC426913
Post by DaveC426913 » Mon Jun 29, 2020 3:59 pm
Ehh. Now that I think of it, prob'ly closer to 5 degrees.
