The König is back in business
Over the weekend, after figuring out what was wrong and removing the old
steering system, I cancelled the mechanic I had called. And I ordered a new Teleflex SS141 8' Rack
Steering System from go2marine.com
I payed almost $70 extra for 2 day shipping and it worked just as advertised. Shipped Monday at 1000 and it was in my mailbox here at the Joint Forces Staff College right at 1000 this morning.
So I took the big leap of faith and attempted the installation process this afternoon all by my lonesome. It really wasn't that hard to install. Some issues I faced however:
1) The hole that was in the front of the console for the
steering wheel shaft had to be cut bigger. I borrowed a friends hole saw and went to work. Since I already had a hole there the center bit of the hole saw was useless. And it was hard to get the hole where I wanted it without the center bit to guide the saw. The black plastic "bezel" will cover my "mistakes"
2) Also, the layers of wood and fiberglass on the thick part of the console is thicker (probably more than 1") than the hole saw so I couldn't drill all the way through. I had to punch about 12-15 holes with a drill bit and then use my screwdriver like a chisel and bang out the layers one by one. But it worked.
3) I had measured the size of the rack on a Teleflex SS141 at WM (but with a 16' cable so I couldn't use it) and found that it was very close to the same size as my old Detmar system. It was a tight fit but I got it to line up and it works. However, the angle is slightly different and now my depth guage (which is about 3-3.5" deep) won't fit all the way in. It sticks out about 1.5". I may see if I can swap locations with my fuel gauge as it is only about 1.5" deep and should fit. Hopefully my depth guage will fit on the other side but the throttle linkages may get in the way. I will figure something out eventually. For now the depth guage works...it just sticks out about 1.5" farther than it used to.
I still have to drill 3 more holes for the bolts that secure the
steering mount plate to the console. I drained the battery on the drill trying to get that hole saw to cut through the very tough console wall.
Also, the half moon thing-a-ma-jig (terminology???) that came with the new
steering wheel shaft is about 1mm too thick for my current
steering wheel. The old one fits but it is barely big enough to fit in the groove on the
steering wheel shaft and have enough metal sticking up to contact the
steering wheel. But I think it will work.
The new
steering seems very smooth. Much easier than before. My initial thoughts are that the rudders go to full travel before the rack has gone to full travel. Not sure if that is good or bad. Will just have to be a little cautious not to crank the wheel further than the rudders will go.
But the bottom line is that it works. And I can sail my last weekend in Norfolk.
Thanks again to all of you that have given me advice on this issue and for all great info on Macgregors over the past 6 months. I think you guys gave me the courage to take on this project by myself.
