A couple of days ago I was thinking of going with the 3-switch system with VSR (the BEP switch like Paul S showed).
But, now after reading another 1,462 posts going back to 2004 I think I am going to go with the setup that Frank C and others discuss...not having a dedicated start battery as it is not needed.
I think I will go with the 1-2-Both-Off Switch. Have all start/tilt (and alternator as well since I think they are all the same wire on my engine) and the DC Control Panel on the "common" terminal. Then use the odd/even scheme as Frank describes. On odd days I will set the switch to #1 and everything (start/tilt/DC Control Panel) will be powered by battery #1. Battery #2 will sit idle, unused and be there for back-up if needed. Even days I will use #2. I am used to turning my battery on and off every time I use my boat so this is not a big deal to me.
I don't see a reason why I would ever use the "both" position...assuming I didn't screw up somehow or something malfunctioned. And if I screw up really bad I always carry my jumper battery.
Plus I am thinking I will go with the Yandina Combiner as well. My understanding is that this will ensure that both batteries get a charge no matter what my switch is set at.
Thus I am looking at about $35 for a 1-2-Both-Off Switch (I am not sure of the difference...if any...between a
PERKOand a
BLUE SEA SYSTEMS). The
Yandina is about $55. And two Group 27 Wet Cell Batteries are about $90 each at Defender. Total is about $270. Might be able to find batteries cheaper at WalMart or Sam's or something. Might need a few other little things like wire and connectors but I think I already have all of that on my current set up.
But I also have about 7 months to change my mind again...so who knows.
On Edit: Got my Tax Stimulus Check today. I guess I will stimulate the Marine Supply industry...
...before my wife & daughter stimulate the clothing accessory industry...
