Adding slugs to the factory main sail.
Obelix
Post by Obelix »
To be able to raise and lower the main from the cockpit, I want to add slugs to the luff on my 2008 :macm: .
How many slugs are needed and at what distance from each other should they be mounted?
As always, thank you for your insights.
James V
Post by James V »
There is a lot of threads on this via Search -
http://macgregorsailors.com/phpBB/searc ... de=results
Unless you know what you are doing it might be better to take the main to a sail loft (somebody who works on sails). The botton is the hardest as you will need to put in a rope system to get the sail down far enough. Check the mods on this.
deja_vu
Location: Salt Lake City, UT '07 26M Merc 60BF "SnowDrifter"
Post by deja_vu »
Just finished adding them using the KH kit. The instructions are't quite right, ifyou space them anywhere close to 12" you'll end up running out of slugs a little after 13'. Anyway spaced 18" apart per some of the other posts you'll use all 15 in the kit. Took a whopping 25 minutes to do. I took some pictures so when I get a chance I'll do write up. Very easy to do.
Obelix
Post by Obelix »
That was the reason why I asked, I got the KH kit but the instructions made no sense at all. Either you run out of slugs after 13' and need additional parts or the recommended spacing had to be wrong. I'm still thinking what to do on the bottom, since the rope-channel is cut of for about 1 foot on the bottom on 2008 masts.
Thank you everyone that chimed in.
Jurgen
c130king
Post by c130king »
Can one of you guys list what comes in that $39 kit from KHM? I will need one for my new sail that I got from KHE.
If I have some of the kit already (like a sail slug stopper) I wonder if it would be cheaper to order the other pieces seperately from a marine supply place (life Defender).
live2shift
sail slugs - Reef point
Post by live2shift »
My 26M came with them in all holes except the reef point, do you guys usually put one in there?
c130king
Post by c130king »
What holes are you talking about?
parrothead
Post by parrothead »
Some sail slug kits employ grommets [creating holes in the leading edge of the sail], some do not.
No slide is installed at the reef point, since it gets slipped over the reefing hook at the side of the gooseneck, becoming the tack of the reefed sail.
Obelix
Post by Obelix »
C130 King,
The kit includes 15 slugs, 15 shakles, 15 screws and a sail-stop.
Jurgen
c130king
Post by c130king »
Thanks.
I just ordered 20 3/8" slugs and 20 5/8" shackles from sailrite. Total was $25 plus shipping.
Probably don't need 20 but will have a few spares.
I will forego the grommets and just use the screws through the material behind the bolt rope.
pokerrick1
Sailboat: Venture 23
Spares
Post by pokerrick1 »
c130king wrote: Probably don't need 20 but will have a few spares.
The spares you will absolutely eventually need - - - you will break some plastic shackels.
Guys; if he forgoes the grommets won't the sail rip apart at that edge - - - will it last :?: :?: :|
Rick :) :macm:
c130king
Post by c130king »
My current sail does not have grommets...at least I am pretty sure it doesn't. Haven't seen it in nearly a year but I think I would remember if it had that many grommets.
And I read some other posts (search on "sail slugs") and seems like several others went that route as well.
deja_vu
Post by deja_vu »
The screw ones have a post that you place right off the bolt rope, all the tension will then end up on the bolt rope and not the screw, I'll try to post the pics I took tomorrow.
TAW02
20 pieces screwed in
Post by TAW02 »
I have an M and I screwed 20 of those suckers (shakles) into my sail boltrope area. Hope I didn't overdue.
Big T
PS, I put one every 16" and like I said, I used 'em all. All 20 that I bought!
Oiy Veh!
tangentair
Post by tangentair »
Bill from Boats4sail rigged mine as part of his upgrade package and they worked fine all last year. They are 24 inches between until just above the reef point then the next is 24 inches from the reef point to the base. The tip has 2 closely spaced. Pictures follow:
The sail looks like this:
the Tip has two closely spaced at 5 and 9 inches from tip
the rest are 24 inches on center
down to just above the reefong point
starts again 24 inches below the reef point
and is 27 inches to the final one
to the base of the sail.
And yes Jim he uses grommets.
