kmclemore wrote:I will say that the Mac trailers are indeed minimum standard... it's actually a shame, since the boat is pretty dang sturdy.
On mine, the axle beam bent in a sway (down in the center) such that the wheels were substantially cambered out at the bottom and it pretty much ruined the first set of tires I had on it. I had to manually re-arch (bend) the axle beam with a bottle jack, and using a spirit level at the two wheels I managed to get them reasonably vertical. Not sure how long the fix will last, but so far (about 3000 miles) it seems to have worked. But the axle should never have been so flimsy... it really was marginal for an unloaded boat, and once you get stuff on board and any mods, you're way over what it was designed to handle.
APPLES AND ORANGES!
I owned a MAC25 and the trailer it came with was a bit less a quality trailer than that of an
It actually flexed the axle to the point that it did bend and cause the wheels to camber-in.
Besides that, an
trailer has a much smaller STRAIGHT axle. It has LEAF SPRINGS and FOURTEEN INCH TIRES.
on the other hand gentlemen ...
An
Aluminum trailer has a PRE-STRESSED ARCHED 4" BOX GALVANIZED AXLE, with 15" TIRES. IT has NO LEAF SPRING SUSPENSION!!!!!! It has FULL TORSION SUSPENSION
What puzzles me gentlemen is what PILOT is talking about. How is his claims possible? This trailer is an excellent hauler for this boat.
PILOT Sir. Please do me a favor and open your gate valve and dump your ballast tank.
then ...
tell us not that you bought your rig from Mr Macgregor, but rather by whom you actually purchased your rig (dealerwise).
Tell us about that experience and how all this dissenchantment evolved.
Thank you
Big T
