Decided I really ought to build one of those mast crutch things so many of you have posted about...I jury rigged an extension on the mast carrier on the stern so that I could work in the cockpit and install the dodger without the mast being in the way. But now I'm not sure it has enough support in the middle and I want to address that before I cover it. Contemplated what a mess that 5200 stuff can be in (on) the hands of an amateur.....
But the real point of this post is that I am now wavering on my decision about where to locate the shore power inlet. I plan to place the new AC distribution panel on the starboard cabin bulkhead next to the hatch. (The new DC is going on the port side where the original one is). I had originally intended to run my shore power through the well on the transom but now I am thinking that I could just drill that big hole in the starboard cabin wall (sorry, do we call that a bulkhead too?) and have direct access to the back of that AC panel.
So...I thought I would ask your opinions. (Which is one thing there is no shortage of here!) As a newbie I have never hooked up to shore power at a Marina! Is the location of the inlet much of an issue? If I place it on the transom will it get in the way if I enter through the stern (not that I would likely do that when I'm sitting at a dock). Am I missing anything here? Is there another location I haven't considered that might work better? I imagine that most of the time I'm plugged in I will be in my driveway but I hope to eventually venture out into deeper waters!
Russell
