Viswhiz,
Here's a few shots of my hoist and my 26X, when I did it.
http://www.box.com/s/24e664a9c5574914851c
Let me know if the link works okay for you.
I'll be putting my D boat back on the trailer tomorrow (weather permitting). I'll take some pics, as I'm going.
If you full screen the pic of the hoist, you can see the two come-a-longs (one on each end of the hoist). I put a nylon load (10,000lb.) binder under the boat and hook each end to each one of the come-a-longs. These are 4 ton lift each, btw. Then I hoist away, first one side and then the other, until the boat is high enough. I usually have a couple cement blocks sitting nearby, to set on the bow, to balance the boat, because I tend to get the strap too far forward most of the time.
The D boat only weighs about 1600lbs if everything is removed from it. The X boat is around 2300 and you may notice, when I did it, I left the outboard on and used my fresh water tank (up front under v berth) to balance things out. I lifted the X by the chain plates, but they are way too far forward on the D boat.
You need about four old tires (off the rims), and some old carpet. The tires will cushion the boat fore and aft and the mid section of the hull will sit on the carpet. Put some of the old carpet on the tires too and you won't have to clean skid marks off the hull later.
Now, if you don't have a hoist, or don't want to build one from timbers, you can build a stand that will slip under the rear of the boat. Then using a couple of floor jacks, work the trailer out from under the boat. Lower the trailer jack as far as possible and build the stand to fit in under the, now much higher, stern. Raise the trailer jack and your boat will be sitting on the stand and the very front V of the trailer. Now use well padded floor jacks alternately, to raise the front of the boat so you can move the trailer out.
I like to use a hoist, however, because it is easier to get the boat down on the ground and back up. I am going to upgrade this soon by adding a real electric hoist to it. I've had the electric hoist for a couple of years now, just need to weld some mounting points to the top of the structure so I can bolt it up there.
To careen the boat over, you can run a good line (I use an old halyard) from a good attachment point on one side of the boat (I use the stanchion mount, close to the sheet winch) over the cabin. Then with your tow vehicle, tie the line to the trailer hitch and pull from the opposite side. Use plenty of padding on the hull amidships. You can get the keel almost waist high, which makes it easy to work on the bottom. I'll do one half of the hull then flip her the other way to do the other half. I used to put the mast up and pull them over by tying one end of the mainsheet to the halyards and the other end to a fence post, truck, or any good anchor point. Getting too old to heave one over by hand though.
I turned my Catalina 22 completely upside-down, but this took a little more engineering and a wooden rack built over the cabin top. (I'll add a pic of this to the boxnet link, just so you can see it)
It was really sweet to work on the bottom this way.
Anyway, feel free to ask any questions. I'll help you any way I can.
Best Breezes,
Steve K.
