The halyard is only a little longer than the luff, so when you lower the head sail, you have to bend on a messenger line so you don't lose the tail. You use the messenger line to hoist the sail, at least until the halyard is low enough to grab and pull directly. Make sure you pull the halyard in line with the slot it rides in, or you'll be fighting a harder battle than you need to.Neo wrote:The CDI manual is driving me nuts!!kadet wrote:As you are in OZ Neo use 8mm double braid polyester for your heavier lines and 6mm for the lighter ones.
My Halyard is knotted off at the top ... so it only runs up one side of the luff .... I don't think that right??
Once the sail is almost all the way up, and you've shackled the tack to the furler drum, you need to snug it down to get the wrinkles out of the luff. Use something like a truckers' hitch. Then tie it off.
