makes good sense, and factual.... Moe,
but when i re-propped downward, i lost a couple of miles per hour top speed, based on numerous observations with the GPS, going and coming, a noticable overall drop, even though i did not do an averaged back and forth run under strictly controlled conditions.
IF the motor gained RPM towards it powerband, which has any sort of parabolic curve, I was looking for some speed increase, not loss. As i drop the prop pitch even lower, i now suspect i will get more revs, but less speed, or no noticable gain. Otherwise the graphed curve would be more of a "S" shape, Power, RPM, vs. Speed, @WOT.
I realize that the curve may have a thresh-hold RPM for its power band, but are you sure that a lesser pitch prop's less thrust @ a given RPM will be compensated by the increase of RPM, and at its max power realize higher speed ?
I am angry at myself somewhat for buying this boat/motor together, and at the PO, after finding out that the Merc is not the same age as the boat, but made in the early-mid nineties. He is uncooperative in giving any consideration. It is possible he did not know either, as he bought the boat used, and I did not find out the motor's age until months later, when i was getting some parts for it.(Serial number)
It looks fairly unused and has low apparent paint wear. I had already put extra money into ithe boat and had financing, so doing anything about the deal was too late by then. Although the boat is really fine, i wish i had waited and found a similar boat (Year 2000, or +) with a 4-stroke and more properly matched motor, maybe with a 60, or 75.
SO one buyer's caveat i did not watch for is to make sure of the motor's age and not assume it is the same as the boat. You would normally assume that if not mentioned specifically, the motor year would match the boat on a fairly recent boat. NO? i guess not.
