Needless to say, my first docking experience was pretty embarrassing!
Any tips for docking or links to good youtube videos or other reference material greatly appreciated!
- ALLEN
MaritimeMenace wrote:Hi guys, I finally got launched and am at a local lake marina (). I’m absolutely new to boating (not including sailing classes at OCC in Newport, CA) and have no experience docking.
- ALLEN
dlandersson wrote:Fly me out there and put me up and I will teach you everything I know.![]()
A good point - my dock lines have eye splices at the boat end, and they're adjusted at the dock cleats, so it's just a matter of flopping them onto the boat's cleats to secure it initially. When docking somewhere that's not my dock, I do what Wayne says above. Bow line tied to the lifeline stanchion at the cockpit, and stern line cleated and coiled on the seat. Usually I single-hand dock, even with 'help', so with the stern close, I can step off and control the boat myself, at both ends, even with the wind pushing me off. Some folks use a long loop from bow to stern to do the same thing.Wayne nicol wrote:with the macs, its all about the wind-
they have so much windage- if you are up wind from the dock- just get out parallel to your spot, and let the wind push you in,
if not it can be tricky, heres what i like to do- i put rudders down- so they help at low speed- and will also steer while you have the motor in neutral..
and i reverse park her- so drift past the parking spot, and use the motor in reverse to pull you into the spot as opposed to trying to push in with the wind blowing the bow everywhere..
what i do is take the dockside bow line- run it outside the shrouds, back to the cockpit, then as the stern quarter kicks in, and is nice and close to the dock- simply step off ( you or your sexy deck hand) the boat onto the dock- and just pull the bow in.
and then the helm operator can step off and secure the stern.
in a good breeze- i take a stern line and the bow line - and the person stepping off has them both, and they can easily hold the boat while you secure it.
doing this is the quickest, and easiest to get into a tight moorage- and the best for dealing with crosswinds.
cheers
Wayne nicol wrote:...
like said above- a little bit of practice will go a long way.
You mean even more embarrassing than the first time backing up to the launch ramp?MaritimeMenace wrote:Needless to say, my first docking experience was pretty embarrassing!
- ALLEN
