Posting Signatures is now enabled. Please check your signature settings in your user control panel->profile (click your username top right)
Torsion Bar Suspension
Moderators: kmclemore, Catigale, Hamin' X, beene, NiceAft
Neo
Post by Neo » Sun Dec 30, 2018 11:05 am
Hi all,
Can anyone tell me what's inside the Torsion Bar Suspension units fitted to the Macgregor Aluminum Trailers?
Are the bars plain steel and a do they rust or break over time? ..... Or anything else that goes wrong with these units?
Thanks gents.
Neo
Re: Torsion Bar Suspension
Post by Russ » Sun Dec 30, 2018 12:46 pm
I've always thought they were rubber inside. But I could be wrong.
Neo
Post by Neo » Sun Dec 30, 2018 12:57 pm
Thanks Russ that makes sense.
Post by Russ » Sun Dec 30, 2018 2:09 pm
It still makes me wonder. Can that center square rod rust? Maybe the whole thing is full of grease or something to keep out corrosion.
Good question. Can it rust? As far as I can tell, nobody on this forum has had a problem.
I'd love to hear opinions from the smart guys.
Jimmyt
Post by Jimmyt » Sun Dec 30, 2018 2:41 pm
The caps over the ends of the axle beam are rusting on mine. They may serve to hold the axle and torsion rubber in the axle beam. Don’t know about the condition of the beam itself, but I’m sure it will eventually rust out - and probably like the tongue beam - from the inside out. :|
vizwhiz
Post by vizwhiz » Sun Dec 30, 2018 7:22 pm
Speaking of this - if i wanted to change my old axle and springs on my original steel S trailer to these, would it work?
:) :idea:
Jimmyt
Post by Jimmyt » Sun Dec 30, 2018 8:11 pm
It's a bit of work but can be done.
https://m.youtube.com/watch?v=gDv4o83T4cg
Neo
Post by Neo » Sun Dec 30, 2018 9:13 pm
A good idea turning the frame upside down but I'd personally rather have things welded and fabricate custom fit brackets than use all those nuts and bolts and off the shelf brackets like that.
Post by Tomfoolery » Mon Dec 31, 2018 9:17 am
vizwhiz wrote:Speaking of this - if i wanted to change my old axle and springs on my original steel S trailer to these, would it work?
:) :idea:
I don't see why not. Should give a much softer ride, including when the trailer is empty, as they have a progressive spring rate - soft when lightly loaded, stiffening as more load is added. Unlike 'normal' leaf springs, which have a fixed rate. Normal meaning all the leaves are always in contact.
I would just be careful that the axle cross bar doesn't foul with the hull. The M trailer has a straight cross bar and I believe the hull actually rests on it, but they're available with drop centers, too. Some of them at least can also be indexed for ride height, making it easy to adjust to the existing fenders or tire/hull clearance.
vizwhiz
Post by vizwhiz » Tue Jan 01, 2019 12:15 pm
Thanks Tomfoolery... the axle tube is rusted badly and i was going to replace it eventually anyway. So I’m figuring out my options... the spindles and bearings seem to be fine, it’s mostly just rust consuming my trailer...
Post by Tomfoolery » Tue Jan 01, 2019 12:55 pm
vizwhiz wrote:Thanks Tomfoolery... the axle tube is rusted badly and i was going to replace it eventually anyway. So I’m figuring out my options... the spindles and bearings seem to be fine, it’s mostly just rust consuming my trailer...
If the trailer is rusting away and you'd rather not put too much money into it, a replacement axle for your existing leaf springs is almost certainly cheaper. Just a tube with spindles and brake flanges. Just have to match the spring center distance, top/bottom spring location, wheel gauge, and axle drop. And of course, load rating and bearing type. Just an axle alone is surprisingly cheap.
Neo
Post by Neo » Tue Jan 01, 2019 2:13 pm
Yes Axles are cheap especially if you shop around and buy the tube/bar from a low cost metal supplier. I was shocked how cheap 45mm solid square section bar was. They can cut it to length and you can have new Axle Stubs welded on as a drop Axle. I can give you an axle diagram if you like?
