BOAT wrote:
But don't despair; Bob, I do have a coffee press - (no self respecting Californian would NOT have one) - but again, it's only for my camper or for home use where I have my NRC approved 'Spent Grounds Storage Container' that is picked up by the EPA every week for a nominal fee, (I got good financing).
Use old coffee grounds on your roses. They love it.
Fortunately coffee grounds sink and are environmentally friendly. But they will plug up a sink drain and rinsing the pot at the stern is a bit of a hassle.
Thats why the best coffee makers for when youre going outdoors are portable coffee maker for your car, camping or outdoors activities, 12V coffee makers that you can plug-in to your cars power supply and just use them on the go. I use mine everytime me and my whife go for a hike in the forest, perfect in winter. check some of them here https://coffeforus.com/10-best-portable ... r-camping/
Even though I am now sailing a different sailboat, I still brew my coffee the same way, with my old fashioned metal coffee percolator. The smell of fresh coffee!
hi phil - getting back to mast wires - i am starting a post here next week on an anchor light i got - supposed to be visible for 2 miles i hope you guys like the pictures when i take them i i will be using some wires to light up the anchor light on top of the mast and it is LED and not supposed to use much battery
BOAT wrote: ↑Thu Feb 04, 2021 11:00 am
Boat,
Since you are posting, I'm going to assume you are still alive and well (I hope so, anyway).
Did you ever get your ballast gauge working?
I haven't had a chance to launch my boat with the lead galley yet. Hoping to test your theory of "immediate capsize" in the next week or two.
the ballast gauge is indeed finished - there is a ballast indicator panel on the pedestal and also one in the overhead of the dinette. more pictures are needed - right now we are preparing 'boat' to go into the shop for the regular outboard engine maintenance. mechanic says it takes about a week because he does not know which wear parts to order until he opens up the bottom unit. Maybe just a normal impeller replace and oil or perhaps a few more bearings too depending on what he sees from our first 350 hours (as you can guess we use the motor hardly ever).
we have been using the anchor a lot more since corona the virus came here so I decided to put an anchor light on the top of the mast. i will post the "mast wiring" details when we are back from the motor shop
the lead galley will just make you go faster on a starboard tack. your galley is only half as heavy as the one in the Highlander and that boat is unsinkable.
