socket size for bf50 prop nut
I have to change prop next weekend and my boat is far away. Could somebody check please what size of socket I need for the prop nut of BF50?
DaveC426913
Re: socket size for bf50 prop nut
I just pulled my prop off my BF50 last week and I didn't use a wrench at all. It's held with a cotter pin.
Thank you Dave for the reply. Do you mean the nut was so loose you were able to unscrew it by fingers?
My boat is far away in the middle of nowhere so I could not take a chance and have to make sure I have all necessary tools with me
- Bilgemaster
If you're referring to the "castle nut" with the cotter pin, if your "BF50" model matches those described here, it looks like it's a 16mm: https://www.boats.net/product/honda/903 ... NQQAvD_BwE
The whole prop assembly is shown here: https://www.boats.net/catalog/honda/out ... /propeller
When I had to swap props a couple of years ago, like Dave's, mine was also just "snug".
I keep one of these on my 26X underneath the bench just forward of the galley. Sure, its contents ain't the pinnacle of the toolmaker's craft, but it's often handy for this and that:
Source: https://www.harborfreight.com/105-piece ... -4030.html
Sure, I've got scads of finer tools, but if I don't wanna paw through the inventory, these little 105-piece 4-drawer kits are super-handy if you just wanna grab-and-go. I've actually got a few stashed here and there that I've snagged on sale over the years. And the quality isn't SO woeful...actually semi-decent. In contrast, the quality of their slightly cheaper 130-piece kits truly ARE excremental, and best avoided. They must be made in some different factory yonder staffed by machinists from whatever the Chinese equivalent is of the Columbia Lighthouse for the Blind using melted down cat food cans. The wrenches in that kit still smell vaguely of tuna.
Bilgemaster wrote: ↑Mon Jun 14, 2021 7:44 pmusing melted down cat food cans. The wrenches in that kit still smell vaguely of tuna.
My Suzuki prop nut is the same castle nut. Finger tight with a cotter pin.
- Bilgemaster
You're very welcome. Oh, and make sure and bring a little grease for the shaft and once the old one's off check for any wound up fishing or other line. It won't do your seal there any favors.
That would be the thread. I believe the socket size would be 23mm, give or take.Bilgemaster wrote: ↑Mon Jun 14, 2021 7:44 pmIf you're referring to the "castle nut" with the cotter pin, if your "BF50" model matches those described here, it looks like it's a 16mm: https://www.boats.net/product/honda/903 ... NQQAvD_BwE
I thought I had a spare nut laying about in the garage, but I don't know where it is, so I can't check right now.
Tom
Be seeing you . . .
Be seeing you . . .
- Be Free
I'm pretty sure it's a 22mm but I used a large crescent wrench last time I took mine off. There is a good chance you can take it off with your hands but take a wrench just to be on the safe side.
The procedure is to snug it down, sort of like a trailer hub nut but not nearly as tight, and then back it off to line up the holes for the cotter pin. Always use a new pin!
2001 26X Simple Interest
Honda BF40D
Honda BF40D
- Bilgemaster
Now that I ponder it, 16mm DOES seem a bit teeny. I do hate that fancy footwork they sometimes do with bolt diameter vs. bolt head wrench sizes. There's a Wikipedia article that sort of explains it here: https://en.m.wikipedia.org/wiki/Wrench_size, and it looks like a 24mm wrench might do a good job with an M16 nut or bolt (unless it's some wacky JIS [Japanese Industrial Standard] fastener, like those wonky Phillips-like crosshead "dotted top" screws which are the bane of motorcyclists, and'll round out and strip if they so much as get in the same zipcode as a Phillips Head screwdriver, in which case it might be a 22mm JIS wrench, though a good old 'Murican 5/8" might also give you some joy.)
But yeah, bring a couple of crescent wrenches, and you should be just fine. It won't be like trying to loosen one if the pedestal anchor bolts of the Eiffel Tower, or even a Dodge V-8 manifold. Hëll, a bit of harsh language might even get it to back off.
But if you think YOU'VE got nut pains, my Royal Enfield Bullet 500 motorcycle, kind of an "engineering fossil" still made in India in our Millennium, though based on a 1954 British design last updated way back then from a Pre-War one, uses a combination of SAE, Metric and even a few Whitworth nuts and bolts here and there. Go try and find a ¼ Whitworth wrench on the shelves at your Harbor Fright, Home Despot or wherever! Grab me a flask of buggywhip oil dressing while you're there, OK?
I’ll snap a picture this morning. I’m pretty sure it’s a 1 inch 25 mm
Robitstad,
Welcome to the forum.
What boat are you looking for, and how did you stumble upon us
