KingRichard wrote: ↑Sat Jun 03, 2023 7:45 am
Last stupid question about this, am I supposed to be using the wenches and camcleats for the jib sheets?
Not a stupid question at all, and ask as many questions as you like!
I would say definitely use the camcleats. I'm not sure how else you would secure the jib sheets when sailing.
If you can get wenches to handle your jib sheets, I am jealous.
Using
winches, on the other hand, depends mostly on the wind speed. I find it most convenient when single-handing to time the release and tensioning of my jib sheets such that I am getting the jib close hauled while it is still flapping lose as the bow of the boat passes through the wind. It takes practice, and I don't always get it right.
One little hack I employ if I want to bring the jib sheet in, but don't have strength enough to overcome the force of the wind, is to turn up into the wind, let the sails luff for just a second, haul the jib sheet in while it is slack, then turn back off the wind and continue sailing.
Using the winches requires planning and timing, and is best done with one or two crewmembers.
Unrelated but related - if you want to do anything that requires letting go of the tiller while underway, get a device that will hold your tiller in position. My favorite is the Tiller Clutch
https://www.cccc.edu/cougarbytes/attach ... Clutch.jpg. Many like the Tiller Tamer.
