12v dive pump (compressor)
hello..
i saw a picture of a air pump with a longhose and a second stage on it.
for diving down to 10meters.
but i cant find any information on the web about it. it was about 12kg and pretty small.. does any of you know anything about it??
it would be nice to have something like that aboard...
the mac is little to tight to bring all of my dive gear...
(2x12litrex232bar as main and 6 different stage bottles..)
Regards.. /fred
Regards.. /fred
Introduction to Hookah Diving
Hookah Diving Systems
Hookah Air Compressors
Looks like these would draw anywhere from 50-100 amps powered by batteries through an inverter. Here's another:
12VDC Shallow Dive Systems
When I was younger, Evinrude used to sell something like this in a round, inner-tube looking float, but IIRC, it was powered by a 2-stroke motor, and the compressor had a snorkel that went up in the air to try to get away from the carbon monoxide.
Moe
Moe
- elia
Here is a page for the gasoline engine diving compressor.
http://www.supersnorkel.com/
Bob,
I have considered buying a "Super Snorkel", and would appreciate your opinion of it usefulness.
Elia
Bob,
Elia
thanks....
now i found what im looking for...
http://www.surfacedive.com/Products/Mod ... norkel.htm
Thanks Moe for that...
ive sent a mail to the maufacturer in australia, and if we agree thats what i will buy... just a perfect toy and for me that like underwater photo..
and its in shallow water i get the best color in my photos...
/Fred
/Fred
- Chip Hindes
90 amps charging rate is what you can get from a decent sized automobile alternator running full out. What they call "trickle charging" is what you can get from a standard sized 50HP outboard alternator running full out.FAQ from the website wrote:Surfacedive's quality 'Odyssey ESV-800' Dry Cell batteries are exceptional. They can be recharged directly from your boat's or vehicles generator in around 30 minutes*.
*Time quoted from manufactures users manual; charging current 90 Amps, 14.2volts.
Alternatively, the batteries can be trickle charged in 3 to 5 hours.
So for your 70 minutes or so diving it will take you a good 4-5 hours running the outboard at a decent speed to recharge the batteries.
- technicalman
- Divecoz
Or Figure on
2 sets of batteries or recharging back at the house or back at the slip or. . .buy the gas driven unit in the first place . . As dangerous as the first 30 feet can be, I am truly surprised these are still available to non-certified divers .
- Divecoz
Most now run 25 to 30 feet
Most now run 25 to 30 feet of hose and all are TTBOMK Snuba of one sort or another and some with a bit of a twist here and there . . . feature this one . . .Its Popular too btw
A huge Plexiglas bowl/helmet you set over your head with straps around your chest and air pumped directly into that...bubble so to speak with a weight belt and weighted reef walkers . . Can you say don't slip and let the water in that helmet haha
but what the heck you can't sue me
we are in a foreign country
hahahahah and that is pretty much how it works in resorts around the world . . .
- Chip Hindes
I was under the impression that the original question was asked by a knowledeable, if not certified diver. I second the notion that anyone not SCUBA trained should not be using this equipment either.As dangerous as the first 30 feet can be, I am truly surprised these are still available to non-certified divers .
Interesting that a reputable dive shop won't even fill your tanks if you're not certified, yet apparently they'll sell one of these to anyone with the money.
- Divecoz
Your correct all counts
Poster implied he is a certified diver . You do need your card to get your tanks filled and you can buy these mail order without a cert of any kind . .
DLT at 30 feet max and for a "Competent scuba diver" to free accent should . . . be no problem just don't panic and blow the whole way up , but the time you change over to the pony tank you could be safely at the surface. . IMHO
- Divecoz
I have never tried
Nor needed to buy from mail order but I have always read somewhere in the Cat's /dream books that you would be asked for your cert # or so I thought .. Now that is for Regs and tanks only . In The Beginning they or some maybe most wanted to see your Nitrox cert to sell you a Nitrox Computer but I am not sure that was industry wide ..
