Crappy Horn
snotnosetommy
Sailboat: MacGregor 25
Crappy Horn
Post by snotnosetommy »
Installed an AFI plastic-front flush-mounted electric horn on my M25, forward on the side of the cabin. Out of the way, doesn't interfere with lines. Great, except it seems to take rain water. It used to make a pathetic little buzz after a rain. Then it died. That wouldn't be so bad, but I hadda cut a 2-1/2" hole in my cabin to mount it. :(
Does anybody know of a flush-mount unit that isn't quite so crappy?
Thanks
vizwhiz
Re: Crappy Horn
Post by vizwhiz »
No clue - but I was thinking about adding a horn to my boat also, in lieu of trying to keep the little can-mounted stadium honkers around...
Anyone with any good ideas on this?
The Mutt
Re: Crappy Horn
Post by The Mutt »
Will this one do? :)
Glenn
Re: Crappy Horn
I think most of those horns are a joke. Had one on my runabout. Plus you can't aim them.
The cheap handheld air horn kept at the helm that I can grab and aim at a yahoo seems like the best solution for me.
LOUIS B HOLUB
Re: Crappy Horn
Post by LOUIS B HOLUB »
The "stadium hand held" (very loud) canister has worked perfectly for our crew. Always handy too. Friendly folk seem to enjoy "tootin" and "waving" frequently to one another around here, so the canister unit has worked just fine.
pokerrick1
Sailboat: Venture 23
Re: Crappy Horn
Post by pokerrick1 »
RussMT wrote: The cheap handheld air horn kept at the helm that I can grab and aim at a yahoo seems like the best solution for me.
The key word being "CHEAP" :!:
Rick
PS Plus they work :!:
Matt19020
Re: Crappy Horn
Post by Matt19020 »
I use the AFI horn ..after 3 seasons it works good except I keep losing a good ground and then it makes that low buzz sound you talk about. Before throwing it away I would just double check that you have good wiring...I thought mine was, and I actually purchased a new one and when I took the old one out I tested it on the battery and it worked fine. just my 2 cents
snotnosetommy
Re: Crappy Horn
Maybe you're right, Matt. I'll check my connections.
otherwise, maybe the ol' hand-held tooter isn't so bad.
Re: Crappy Horn
A wise man would have both + a nice loud whistle around your kneck & a good Brass Bell Yep you heard me ! ever been caught in the fog !!
PS All my PFD have an attached fox 40 whistle or louder & an emg. flashing L.E.D. light that activates as soon as you hit the water , If you knew how hard it is to locate M.O.B. in 8ft Sea's in daylight it's almost impossible at night ! you really need to be prepared :idea:
Re: Crappy Horn
Post by K9Kampers »
Matt19020 wrote:I use the AFI horn ..after 3 seasons it works good except I keep losing a good ground and then it makes that low buzz sound you talk about. Before throwing it away I would just double check that you have good wiring...I thought mine was, and I actually purchased a new one and when I took the old one out I tested it on the battery and it worked fine. just my 2 cents
Something else to check with these horns is the condition of the diaphram, for corrosion & debris, and the setting of the diaphram adjustment screw.
vizwhiz
Re: Crappy Horn
Post by vizwhiz »
oh yeah, ship's bell!! That sounds like something FUN to buy!! Admiral will have to weigh in on that one too, to be sure...
Re: Crappy Horn
Better get the Brass' appoval on that one...
vizwhiz
Re: Crappy Horn
Post by vizwhiz »
I'll probably just let her pick it out... :wink:
