We enjoyed our trips to Florida and even working on the Endeavour and if Ruth was still with us I think it would of worked out to of been a great boat for us and we were almost ready to put her back in the water. That didn't happen and I regret the time we could of spent back exploring new places with the Mac.
Well I'm going to have to move on and feel going back to the Mac is the best thing for me. Much easier to single hand, can go places a big boat can't go and most of the same places we would of taken the bigger boat. Now into my 70's I have to start getting realistic about what I can and can't do so want to outfit the boat in a way that I can use her by myself.
I just ordered and received a Raymarine ST2000 Tiller Pilot that I'll install on the boat and that will help a lot. I can even connect it to the computer running OpenCPN and have it follow a course with different waypoints.
I'd also still like to do the NE trip and the Erie Canal and for it and also to be used other times I'm installing a Minn Kota Riptide 80 transom mount trolling motor. It is going to be interesting to see how this works. This is their saltwater 80 lb thrust motor rated for boats up to 4000# and 25 feet in length. I talked to a factory rep and he felt that on 1/2 throttle or less that it should move the Mac at about 3 kt. This will not be the primary propulsion as I'll still have the Tohatsu 9.8 HP for anything other than calm conditions.
I'm hoping, we will see, that I might be able to motor 4-5 hours a day in calm conditions or say on the Erie. To do this I need to top off the batteries of course. I just received six 60 watt solar panels. I'm going to replace the Bimini with 4 of the panels. They will provide shade and power. The 2 additional panels will hinge off the other 4 along the lifelines on each side. Hinge down when not needed or during docking. The 4 center panels will also be able to hinge down above the lifelines for those times I want to have an open cockpit or to put the bug screen up at night.
The motor is 24 volts so 2 sets of panels will be wired in series and run to a 24 volt MorningStar MPPT controller and on to two 12 volt group 27 deep charge batteries in series also. The other two 60 watt panels will be wired in a way that they can either go to the 12 volt MPPT controller that charges the house bank batteries (changing these to two 6 volt batteries in series) or to the 24 volt controller connected to the trolling motor batteries. This will either up the current 200 watt house bank solar array to 320 watts or will give 360 watts total to the trolling motor batteries (still leaving 200 watts for the house batteries).
On a good sun day the 360 watts going to the trolling motor should power it at low to medium speeds as long as their is sun. At least on paper that might work. I received the motor, MPPt controller and a lot of aluminum over the last couple days and have started on the project and will post more here and of course on my site.
Here is a preview...
I constructed a battery box, yet to be stained and sealed, for 2 batteries for the trolling motor.
It will mount under the companionway next to the 12 volt fridge.
I got the motor in 2 days ago and in an hour mocked up a mounting location for it. This will be replaced by a much smaller mount right where the motor is in order to keep the ladder access free. I mocked up the rudder to make sure that it would clear it.
continued in next post........
Our MacGregor 26-S
Our Endeavour 37
Mac-Venture Links
