Tattoo 26 For Sale at Smith Mountain Lake, Virginia
Bilgemaster
Post by Bilgemaster »
You just don't see a helluva lotta Tattoos pop up for sale on craigslist, and so just stumbling upon this ad for one at Smith Mountain Lake in Virginia asking $20,000, I thought I should pop a link to it here in our "Tattoo" section: I hope you'll forgive me for disturbing any long-cherished cobwebs here. See: https://roanoke.craigslist.org/boa/d/un ... 36273.html
The ad's got pictures of different boats of various hull colors....maybe from company promo shots? But if you're interested in a Tattoo, I'm sure you can work out which one is actually being sold with the seller. I suspect it could be the dark blue hulled one with the Virginia registration numbers seen up in a dock lift and also from a distance in the water at the same dock, but caveat emptor!
Just for posterity's sake, here's the text of the ad:
2014 Tattoo Motor Sailor w/ Trailer (successor to the MacGregor 26M)
Located at Smith Mountain Lake, Virginia
Fully equipped with Dealer options, plus after-market
LOA – 25′ 10″ / LWL – 23′ 2″ / Beam – 7′ 8″; Draft, board up – 12″ / Draft, board down – 5′ 9″
Evinrude ETEC 60 Hp outboard motor; Speed when motoring – up to 19 knots
Main sail – 189 sq. ft. / Roller furling Genoa jib – 183 sq. ft. / Cruising Spinnaker – 350 sq. ft.
Mast height above deck – 30′ 0″ / above water – 35′ 0″
Water Ballast – 1,172 lbs / Boat weight (less ballast) – 2,500 lbs. / Trailer weight (standard trailer) – 710 lbs.
See www.tattooyachts.com for more information
Asking price - $20,000 Original purchase price - $44,164, plus extras
NADA suggested retail (for similar 2012 MacGregor 26M – closest match available) - $30,335
