Mast fittings
G4s1198
Sailboat: Venture 21
Mast fittings
Post by G4s1198 » Tue Oct 13, 2020 6:12 am
Greetings all! New member here. I just acquired a venture 21 from a fellow who’s dad was restoring the boat. Unfortunately some of the hardware is mixed up/missing. I’m trying to figure out how the mast attaches. There is a U shaped hinged fitting at the foot of the mast that swings with a metal peg on the bottom. Also it came with a SS fitting that is 3 sided and has a slot on each side. How the heck does this thing go together?? Lol. There is a hole on the top of the cabin that appears to fit the peg fits in but that’s as far as I’ve gotten. Any help appreciated!! Thanks
Re: Mast fittings
Post by Jimmyt » Tue Oct 13, 2020 6:38 am
Copy of manual here: https://macgregorsailors.com/resources/ ... Manual.pdf
It shows stock boom connection. If yours doesn't look like this, or you can't figure it out, take a pic and post it. I'm having trouble visualizing your description.
Freedom77
Re: Mast fittings
Post by Freedom77 » Wed Oct 14, 2020 8:20 am
per Jimmy T, Send a pic.
OLD SALT
G4s1198
Re: Mast fittings
Post by G4s1198 » Thu Oct 15, 2020 3:48 pm
Here is the bottom of the mast and the fitting thanks guys!
G4s1198
Re: Mast fittings
Freedom77
Re: Mast fittings
Post by Freedom77 » Fri Oct 16, 2020 9:20 am
The fitting is for transporting the mast while trailering. The setup was a bracket on the foredeck that the tube part fit into. If you don't have the bracket there are probably some holes where it used to be. Check it out and let us know. The "U" shaped piece with the elongated holes is the mast step. Under the deck should be the mast post which holds up the deck. SUGGESTION. Check deck around mast step for cracks, weak spots, etc. I put a 1/4 inch stainless plate under the deck between mast post and deck as reinforcement. Deck is pretty thin at this point. Also check area at bottom of mast post to make sure it solid with no give. Good luck.
OLD SALT
Freedom77
Re: Mast fittings
Post by Freedom77 » Sun Oct 18, 2020 10:03 am
CORRECTION: 1/8 STAINLESS PLATE. Aluminum will also work.
OLD SALT
