Changing trailer tire size
trswem
Sailboat: MacGregor 26D
Post by trswem »
Hello. My trailer for the 88D came with 215/75r14 tires, but noone stocks those around here. Has anyone swapped tires for something that's a little easier to get a hold of?
Location: Ambler, PA -- MACX2018A898 w/ Tohatsu 50D -- 78 BW Harpoon 4.6 -- 2018 Tahoe 550TF w/ 150 Merc
Re: Changing trailer tire size
Tractor Supply can get them for you - you can buy then and pick them up at the store. TS is a great place to look for trailer parts and supplies... they have a lot that matches our Mac trailers.
https://www.tractorsupply.com/tsc/produ ... ire-470218
How about some 5 ft - 6 ft tires like you see at auto shows? Make it easy to get under the boat on land. :)
trswem wrote: Thu May 30, 2024 4:13 pm Hello. My trailer for the 88D came with 215/75r14 tires, but noone stocks those around here. Has anyone swapped tires for something that's a little easier to get a hold of?
Be Free
Post by Be Free »
To answer your question: as long as the lug pattern matches your hub, any change in diameter does not cause the tire to rub on the fender or boat, any change in the width does not cause the tire to rub on the fender or the trailer, and the tires are rated to carry at least as much weight as the originals you should be fine.
On the other hand, what you currently have on the trailer should not be hard to find. Good luck.
2001 26X Simple Interest
Honda BF40D
trswem
Post by trswem »
Be Free wrote: Fri May 31, 2024 5:12 am To answer your question: as long as the lug pattern matches your hub, any change in diameter does not cause the tire to rub on the fender or boat, any change in the width does not cause the tire to rub on the fender or the trailer, and the tires are rated to carry at least as much weight as the originals you should be fine.
Thanks Be Free. The local marine and trailer stores didn't carry these, but I was able to order them through West Marine. I went ahead and got new wheels too, mine were looking pretty sketchy. $515 for two tires/wheels for interested parties in posterity.
Be Free
Post by Be Free »
trswem wrote: Fri May 31, 2024 9:06 am
Ouch!
Honda BF40D
OverEasy
Post by OverEasy »
Hi Trswem!
That $515 quote seems a bit high. :| :o :?
I just did a quick search on Walmart.com and came up with the following:
There are more but it gives a general cost perspective for new trailer tires 🛞 for the size you are looking for.
The average cost is about $70 each or about $140 for a set of two.
(It’s not that I like Walmart but it generally ships nearly anywhere to a store, business or home.)
A standard rim to fit this model size tire is:
This is about $60 each or $120 for a set of two.
So for a new set of tires and rims would roll up to $140 + $120 = $260 (plus mount and balance).
Hope this is of some help….
Best Regards,
Over Easy 😎😎🐩🐈
