importing a second hand Mac 26 from USA
Stui
Post by Stui » Sun Nov 21, 2010 8:25 pm
Arr Me-Harties
I am just about to buy a second hand Macgreggor 26X from a dealer in the US
On the Macgregor 26 website the width (beam?) is specified as 7'9" a standard shipping container has a door width of 7'8" so How can you get it in to a container?
I tried three shipping companies and they all only have a 7'8" door opening.
It is possible that there are certain containers that are wider or is the Mac 26 only OK for shipping around the US?
Has anyone got any advice to give me to get a Macgregor 26X into the container?
I'm not interested in using any lubricants for this appilcation (water based or otherwise)as I do not want to "insert technical term here" the boat during shipping.
Please let me know your ideas
Thanks
Stuie
Hamin' X
Re: importing a second hand Mac 26 from USA
Post by Hamin' X » Sun Nov 21, 2010 9:00 pm
I have not heard of the problem before. Perhaps a slight tip to the side will solve the dilemma. Where are you located?
Stui
Post by Stui » Mon Nov 22, 2010 2:15 am
Yes that would work, need to rotate the hull on the trailer and adjust the supports
trick of the trade-Good thinking 99!
Mistral
Location: Patterson Lakes, Melbourne, VIC., Australia 2005 26M "Indigo Blue" 50HP E-Tec
Post by Mistral » Mon Nov 22, 2010 2:53 am
Stui,
The 26M has the same dimensions and quite a few have imported these with no problems.
Stui
Post by Stui » Tue Nov 23, 2010 2:57 am
Can youthink why the Macgregor website puplishes the width of the 26 as being 1" wider than the standard shipping container?
must be a typo by Laura.
I am not put off bringing in my own boat so I'll soon find out & let you know.
S
Scott
Post by Scott » Tue Nov 23, 2010 4:18 am
Look up "The Mutt" here on this website. He imported one to down under.
mtb_gary
Location: Perth, Western Australia "Lochan Ora" 2006 26X lots of mods for cruising 40HP Nissan
Post by mtb_gary » Sat Nov 27, 2010 6:31 pm
Go with a roll on roll off. You don't need to dismantle (or angle grind) any part of the trailer. It also means you are ready to tow away once the boat arrives rather than having to drag the boat out on it's axles (wheels need to be removed for height clearance).
Gary
The Mutt
Post by The Mutt » Thu Dec 02, 2010 11:24 pm
Macgregor 26X inside shipping container, the hull was not spun, twisted, etc to get in.
The axles and guards had to be removed from the trailer.
And a way to slide the boat while still on the trailer bed had to be made.
If i was doing it again I would ask someone to undo the nuts so the cabin to life line posts could be strung up against the mast, one of ours was cut with an angle grinder.
A bit more of the story is here http://devinetemptations.com/macgregor2 ... tainer.htm
I have been sent quite a few questions via email, when I get some time I shall be posting the questions with the answers i gave on our web site to hopefully help others, until then if anyone has any questions ask me via the web site, I haven't had much time to browse Macgreor Sailors of late.
Glenn
Reason: Repaired Link
Scott
Post by Scott » Fri Dec 03, 2010 3:40 am
Every time I see that I think its pretty cool
Boblee
Post by Boblee » Sat Dec 04, 2010 11:12 pm
If the little wheels are still under the trailer you won't need to worry, started to cut mine off and found it too difficult so left them there.
rustyleggo
Post by rustyleggo » Sun Dec 12, 2010 7:17 pm
Does anyone know the cost of shipping via container compared to shrink wrapping it and using roll-on/roll-off (on trailer)? :macm:
The Mutt
Post by The Mutt » Sun Dec 12, 2010 11:37 pm
rustyleggo wrote:Does anyone know the cost of shipping via container compared to shrink wrapping it and using roll-on/roll-off (on trailer)? :macm:
When we were getting prices RORO was bigger $$$ than a container, sorry I don't remember the exact value, from memory it was around half again what the container cost.
I was told the containers cost more because they stack.
Some ships are stacked better than others! :wink:
Glenn
