Winter fuel additive?
Post by dlandersson » Mon Oct 18, 2021 11:05 am
Anyone suggest a good wnter fuel (87 octane gas) additive? 8)
chipveres
Sailboat: MacGregor 22
Re: Winter fuel additive?
Post by chipveres » Mon Oct 18, 2021 3:06 pm
Well, I like Sea Foam if I am running the engine or Sta-Bil for storage. But us Florida folks don't really know anything about winter.
Chip V.
S/V Sand Dollar
Shawnmcgr
Post by Shawnmcgr » Mon Oct 18, 2021 6:56 pm
I 2nd sea foam I used in all my small motors, snowmobiles, weed Wacker, and my nissan 40 hp 2 stroke in our macgregor. I use it to stabilize over winter and periodically dump a bit in the tank to clean the fuel system.
Great stuff!
Post by dlandersson » Wed Oct 20, 2021 9:39 am
Yeah, I've used Sea Foam in the past and it says "Fuel stabilizer" on the can so I'll stick with it. Thx. 8)
Great stuff!
Post by Russ » Thu Oct 21, 2021 6:13 am
My understanding is alcohol in the gas is a problem when storing over time.
I've come to use pure gas exclusively. Most gas stations here that use 91 octane are pure gas.
I also try to run all the gas out of line and siphon as much gas out of the tanks as possible. I hope I'm doing right.
Post by Tomfoolery » Thu Oct 21, 2021 6:22 am
I fill the two 6-gallon boat tanks with ethanol-free gas with Stabil, and store them for emergency generator use. I also keep the generator's 5-gallon tank full, and my two 5-gallon metal 'safety cans', all with Stabil. An ice storm can really ruin your day without heat and hot water. And Netflix and Prime, though I also have an antenna in the attic as a backup. But I digress.
I run the engine out of gas, then drain the three float bowls. They have drain valves and even a couple of hoses tucked inside, just for that purpose. There isn't much else you can do as far as gas goes.
Tom
Be seeing you . . .
mallardjusted
Location: Puget Sound, 2001 Sold Oct2021 "Aqua Dawg", 70hp Yam
Post by mallardjusted » Sat Oct 23, 2021 12:07 pm
I love Seafoam for a "spring cleaner" in my outboards, lawnmower, and generators. But, since it has Isopropyl Alcohol in it I don't use it for storage. I use Startron with good results for that. Stabil also will work great. Here's a link on fuel additives, and they state it's best to use ones without any kind of alcohol in them ......
http://www.fuel-testers.com/is_gas_addi ... _list.html
Post by NiceAft » Sat Oct 23, 2021 4:05 pm
I have used Sta-Bil for a long time.
The fellow who has been winterizing Nice Aft for years tells me he uses this.
He says it’s better.
Ray ~~_/)~~
Post by Highlander » Wed Oct 27, 2021 10:55 am
Ray do u feel flushed after drinkin it ! :P :?
