I suspected low oil as I forgot to top it off. Sure enough the oil reservoir looked low so I poured in a quart. Restarted, horn went out...hoo-ray Jim is a "Super Genius"...
Hold on there Mr. Genius...the horn came back on after about 30 seconds...Dohhhhh
Looked in the manual. Either overheat or low oil. The engine was "pee-ing" just fine and the water didn't feel hot at all. And I had just put oil in. The horn stayed on for the next hour all the way back to the marina. But the engine worked just fine all the way back...normal RPMs (5300 at WOT) and normal speeds (16-17 MPH with no ballast, two people, and against slight headwind).
I took the engine cover off and the motor felt fairly hot...but I have never tested the temperature underneath the cover before so I am not sure if this was unusually hot or just the normal temp after running the engine for over an hour. But nothing looked wrong (but would I even know???) And as I said the water pump was working fine and that water didn't feel too hot to me. And I think the engine was maybe just a little bit "smokier" than normal...but not sure about this...could have been my paranoia as I was closely monitoring the engine all the way back.
I am hoping that the motor will "reset" itself after being completely cooled. And if it works properly today I will pay attention to the temperature under the hood and the level of smoke.
Any thoughts from those of you more mechanically inclined than I...which would probably be over 90% of the members of this distinguished board...
