Rub rail change for MACGREGOR 26s
Hi Folks,
I was wondering if anybody can share info where to purchase rub rail for 1990 MacGregor 26S?
Any info would be appreciated, thank you!
Mars
Mars
Re: Rub rail change for MACGREGOR 26s
Purchase Here
http://shop.bwyachts.com/product-p/h103-1v0.htm
And there is a video of replacing it here
https://www.macgregorsailors.com/resources.html
Thanks, but the site points out "Used only on boats 1992 and newer. We do not have the older style rubrail available." Mine is from 1990. Is it the same rub rail?
- Hamin' X
Best bet is to call, or email BWY. They may be able to help you source the part.
~Rich---Hamin' X---N7ZH~
- Sailboat: Venture 25
Are you looking for the rubber strip or the actual aluminum extrusion?
Well, 26s from 1990 does not have aluminium extrusion, it's only rubber rail.
