I want another cleat on the mast of my 26s. This is needed for hanging the excessive main halyard that I insist on, and for hanging the jib halyard that is not used (roller furler).
Do I have to use backing nuts? Several feet in from the bottom of the mast, I don't have a good plan for holding them with a wrench while tightening the screw. Can I just drill a hole and drive in a machine screw?
Or, since this is for hanging line rather than cleating a loaded line, would it be better to screw in a hook and call it good?
--john
Mast Cleats
- Starscream
Re: Mast Cleats
Personally, I'd just drive in a screw, especially for a non-loaded line. A nice stainless self-tapping one.
Or use rivets?
Or use rivets?
Re: Mast Cleats
I have 2 cleats that I don't use at all.
I removed the Jib halyard since I have roller furling and it's not used. I can't find a reason to keep it.
Main halyard is run to the cockpit.
- Chinook
Re: Mast Cleats
26X mast raising pole requires use of the jib halyard for raising the mast. I've also used it as a temporary mast support by tying and tensioning it to the bow pulpit, while I disconnected the roller furler so I could turn it around, after rigging it with the line opening facing forward instead of aft, although I suppose the main halyard could also do the job.
Re: Mast Cleats
I removed the jib halyard, and use the spinnaker halyard for the MRS.
Tom
Be seeing you . . .
Be seeing you . . .
