Hi Kurz!
The replacement of the tub rail is something we did for Over Easy early on not long after we adopted her. At the time I wasn’t physically up to doing it (or much else back then with then current physical restrictions/health issues) so we had our local boat yard do it. It want terribly expensive or difficult really. If we were to have to do it agian we’d do it our selves.
There isn’t a wider rub rail than what BWY offers that I’m aware of.
The removal of the old rub rail , cleanup of the flanges, repair of any damaged fiberglass, replacement of compromised hardware isn’t all that difficult. Call BWY and talk to them. I believe they will have all the materials and process instructions you will need. The whole process isn’t hard especially if you have someone to be an extra set of hands. The boat yard did it with just one guy.
I believe BWY will just send you the instructions if you ask.
That way you can get the supplies locally if that works out better for your situation.
Best Regards
Over Easy
