A few boat stuff updates
Ixneigh
Post by Ixneigh »
Hi everyone. Ive been using the boat quite a bit but not going very far afield.
Here are some updates on some stuff Ive had on the boat.
Water based nonskid. Yes, its rough. After applying it nearly everywhere on deck, someone mentioned that my boat looked like a skateboard. :D I put the stuff literally anyplace Ive ever slipped. Love it. Stuff adheres well to pretty much everything. Metal, gelcoat, plastic. Seems to be holding up well. Much better than Durabak, and easier to apply. Water clean up.
Heavy duty rudder brackets. Still not thick enough, mine have a very slight bend, despite my new rudder pivot system which decreases loading on the plates drastically. I have not really sailed the boat hard either. They are better than the factory ones, to be sure. My factory ones were very bent. These are just slightly bent.
Tohatsu 20, motor downgrade. Its taken some time to adjust my habits back to having a smaller motor. What it lacks in grunt, it makes up in finesse. It does particularly well in the three to four knot range which with me is nearly always. No regrets.
My giant (mast) balls. Yep, still balling! No problems, mast pivots easily.
Computer cooling pump galley pump, runs on 12v makita battery. Wonderful. Maybe charge the battery once a month. I live on the boat full time from nov to may. Its hooked to a pressure switch you can operate with your knee. Simple anf cheap.
Ix
"Shoal Idea"
2011 M, white
Tohatsu 20
South Fl.
Re: A few boat stuff updates
This really grabbed my attention. :)
Ixneigh wrote: Thu Apr 09, 2026 8:45 pm
pitchpolehobie
Post by pitchpolehobie »
dlandersson wrote: Fri Apr 10, 2026 7:13 am This really grabbed my attention. :)
Yea i dont remember that one. Give us a refresher maybe with or without pictures..
2002 MacGregor 26X: Remedium
Tohatsu 25HP
Link for the nonskid product? 8)
quote=Ixneigh post_id=377197 time=1775792737 user_id=12858]
Water based nonskid. Yes, its rough. After applying it nearly everywhere on deck, someone mentioned that my boat looked like a skateboard. :D I put the stuff literally anyplace Ive ever slipped. Love it. Stuff adheres well to pretty much everything. Metal, gelcoat, plastic. Seems to be holding up well. Much better than Durabak, and easier to apply. Water clean up. x
[/quote]
Be Free
Post by Be Free »
You caught my attention with the "giant mast balls". I thought someone here was actually using day shapes! Now I'm sad :cry:
I'd like to hear more about the water pump. That sounds like it might be something I'd try.
2001 26X Simple Interest
Honda BF40D
Ixneigh
Post by Ixneigh »
Mast balls. The very much larger mast bearing i made to replace the small ones which Blue Water sells. I think there are five 3/8" SS ball bearings held captive in a starboard plastic retainer which is just a disc with holes drilled in it for the balls. This mod requires cutting 3/8 off the mast base. I have the largest balls of anyone on this site (a bit ironic) since Im pretty sure no one else has done this one yet.
Sink pump uses a 12v computer cooling pump connected to a cordless tool battery by means of a knee switch. I used a piece of copper tubing for the spigot. It must be the ansolute cheapest means of having running water. Note I have a 9 gallon tank under the sink.
The knee switch made from a horn button switch
"Shoal Idea"
2011 M, white
Tohatsu 20
South Fl.
pitchpolehobie
Ixneigh your mods are always impressive and demonstrate rhe flexibility of the 26 design. Well done!
Tohatsu 25HP
OverEasy
Post by OverEasy »
Hi Ixneigh!
Thanks for the update!
Like the push button water! Nice!
Post a picture of the non-skid if you can.
We’re gonna have to do something for our existing grip areas if/when we ever get to giving/getting Over Easy a paint job.
Best Regards,
Over Easy 8) 8)
