http://youtu.be/ele_X89tmJg
So I was thinking, grind out the cracks so I can see where I'm at, and then probably grind and sand about half the thickness of the rudder away from the damaged side, down a few inches below the major crack. Then build it up layer by layer, grind, sand, and finish with flowcoat.
Have only done fibreglass patches on dinghys etc before and this is a little more complicated so thought I'd thow it out there first.
So brains trust, does this sound like a decent plan of atack? And also, does it matter which resin I use?
Paul.
ps. I have seen it said that, as a sailing boat, the rudders are the weakest point of the Mac. Well that "may" be true, but all I can say is, reversing into that sandbank yesterday would probably have turned out considerably worse (and expensive) for any other 26 foot sailboat
