The water level was above the intake but the turbulence was creating air bubbles and it wasn't picking up. A couple more inches of water and it's fine *fums up
Not a mast raising device. My guess is some sort of docking/mooring assist, but I've never seen anything quite like it.Drifter wrote: ↑Sun Nov 15, 2020 4:15 amhttps://www.dropbox.com/s/d6npwhos19uyw ... 5.jpg?dl=0
I have this pole in the boat... was under the rear berth. I'm presuming this is some kind of gin pole to extend the jib when going down wind?
Or could this be the missing mast-raising pole?
The fact it's plastic makes me feel it's not for the mast raising but hey, I dunno?
Well, I don't know what it is, but I'm not the sharpest knife in the drawer. Give it awhile so the smart guys have a chance to look at it.
Maybe a flagpole? That's going to be my two guesses. Docking/mooring assist, or flagpole...
Hope he responds. I'm curious to see what it's intended purpose is.Drifter wrote: ↑Sun Nov 15, 2020 7:18 amI can try asking the boat dealer to ask the PO, though my one and only visit to Japan a few years ago taught me it's one of the few countries on Earth where most people do NOT speak any English.
Actually I've already sent the pic to the dealer, hoping he'll get the hint and ask for meI'll ask more directly if he doesn't get the hint
I think it was John (Highlander) who recommended using a boat hook for a whisker pole. I haven’t tried that yet, but I will. In light air, there isn’t much load on it, so even a twist-lock type extendable, as opposed to line control, should be perfectly adequate.
In light air, I think the bust hook is a good solution. Though my boat hook only extends to maybe 8', whereas the homemade whisker pole I use extends closer to 12'. Using the boat hook as a whisker pole follows the rule of at least two uses for every item on board.Tomfoolery wrote: ↑Sun Nov 15, 2020 4:59 pmI think it was John (Highlander) who recommended using a boat hook for a whisker pole. I haven’t tried that yet, but I will. In light air, there isn’t much load on it, so even a twist-lock type extendable, as opposed to line control, should be perfectly adequate.
