"your centerboard cable should not need to be pulled excessively tight to retract your board all the way into its slot. You may need to drop the centerboard and make sure there isn't anything lodged in the centerboard trunk. I believe to remove the centerboard that it's just a couple bolts inside the boat at the base of the mast compression post."
Well I've just recently lowered it (with a loud thud!) and cleaned the barnacles off it, sanded it down and re-painted it with anti-fouling paint, or at least as much of it as I can reach.
Problem - when I go to retract it, nothing much happens. With a really hard pull and release I can hear it bonking, so apparently moving an inch or two, but it certainly doesn't seem to be coming up.
Tricky to say just what's going on as I'm working by myself, so can't be under the boat and pulling on the line at the same time, see? Tomorrow I'll climb underneath and see if it is still free to move. It seemed to be yesterday, as I was raising it up and down (from under the boat) to clear all the leaves, shells and other junk falling out of the slot.
Point is, from under the boat it seemed to be easy enough to raise and lower it, but from the cockpit the rope/wire thing just doesn't move much. Feels like it's really jammed.
Is it likely/feasible for the board to be free but the control line jammed somewhere?
Bonus question! At the very end of the centerboard there is a little hole. What is that little hole for? I don't see anything in the manual?
