Interior portside crack
I'm looking to purchase a 91 MacGregor 26S. I've found an interior crack (picture is attached) along the port side between the two windows where the wall and header transition. Is this a common issue with this boat? Likely to be a cosmetic issue or more structural? Otherwise she's clean and appears to have been well cared for. I appreciate your feedback and insight.
Re: Interior portside crack
Is the liner really structural anywhere?
Fiberglass can be repaired. If the rest of the boat is a good buy I'd get it.
I failed to mention in the original post that I am new to sailing. This will be my first sailboat. I appreciate the feedback. Thank you.
