Was wanting to point to a diagram of my current rigging here, but cannot as I don't have enough posts
It is what I assume is a pretty standard setup with the exception of it has a genoa on roller furling.
The first thing on my list is to run the main halyard aft (I've already ordered the sail slugs from Sailrite). My first question is if I want to raise and lower the main from the cockpit, should I also rig a downhaul lead aft as well? I've read some conflicting things about how to run lines aft. Should the block at the base of the mast be connected to the mast base (not actually the mast) or to the base of the mast itself (to ensure mast rotates properly)?
Next, I'd like a boomkicker to keep the boom out of the cockpit without using the main halyard for this when the main is down. I just wanted to verify the boomkicker works with a boom-vang installed (my boat has one)?
Is a reefing system worth while? If so is it also worth while to run the lines aft?
I've looked at main furling systems and other systems to handle automated lowering of the main lazy jacks I think and something from SailCare I saw on this forum, but thus far don't know I want to go for that. Are they a big help?
Also, I bought the boat from a broker who didn't know a lot about sailboats. They rigged the genoa lines incorrectly and I think they also didn't tension the standing rigging correctly. Currently, if I press on the upper shroud with my thumb with decent pressure (but not putting my whole weight against it or anything), I can press the shroud in at least 5 inches (certainly cannot play music on it
Last question (at least for the moment). If I am running a few more lines aft how do I organize these? I already have one cheeck block on deck for the centerboard line. Do I just keep adding more blocks or can I find some double or triple blocks (maybe cheek block that would fit in existing holes of centerboard line to avoid making holes in my new boat.... I'm still a bit scared by that thought) to minimize the number of blocks on deck?
Cheers!
Tony
