Leon
I think sails have to got to be the main culprit. The main is actually the one for a Mac25 (says so on it!). I gather it was specified by the original owner, which may be because it comes with 3 reef points not one. There is a lot of sag at the luff which probably means that when hauled in enough to stop the luff luffing, the sail in total is over-sheeted.
More expense
delevi wrote:How do you like your ST40 wind instrument. I just ordered one. Do you find the wind angle to be accurate with the rotavecta transducer? Where did you mount it? I'm thinking about mounting the transducer on the arch off the transom (mast support unit for trailering.) I will probably mount the display on the port bulkead.
Well so far my experience with the ST40 isn't too good, because I think I got sent a rogue item. To start with some of the mounting parts for the transducer were missing so I had to get those sent on. Now it turns out that I can't calibrate the direction mode. The linearisation (where you do 2 turns in the boat) just keeps beeping and displaying meaningless numbers. If I ignore that and try to calibrate direction anyway, the indication ends up being pretty much random. So for now I'm still using the windex for direction.
Raymarine's tech. support said it was probably a faulty display, so I'm waiting for a replacement to arrive. From comments on this thread I suspect the speed indication may be on the low side too so I'll see how the replacement unit behaves.
I fitted the transducer at the mast head, I made a detachable mast cap, also carries combined windex and VHF antenna.
I bought an ST40 bi-data for depth and speed at the same time, with a transom-mount transducer. This works OK, although speed under power can be a bit off because of the effect of the prop. The transducer is mounted exactly per the instructions, but I guess with 50HP thrashing a prop that close it's bound to disturb the paddle wheel!
I have the two displays side-by-side on the port bulkhead. They look nice anyway.
(You can just see them in
this pic from the set I posted a while back)
Cheers, Rick
