Windsock for air ventalation in cabin
Post by K9Kampers »
Andy / Russ -
Haben Sie Verständnis für die englische Version Anweisungen? :wink:
Andy hipetrol
Location: Lake Travis Austin, Texas 07 26M 50HP Tohatsu
Post by Andy hipetrol »
K9
From my high school German Wo ist Monica? Answer an den see
tangentair
Post by tangentair »
Andy hipetrol wrote:K9
unter dem Meer
Andy26M
Windscoop
Post by Andy26M »
I have one of these windscoops also.
I have a roller furler, so there is no jib halyard available to pull it up with. Instead, I use the main halyard to raise the scoop.
Since the main halyard is too far aft to pull the scoop up directly, I take a piece of small line tied in a loop - it goes around the furled jib and then the halyard comes down through the loop to the windscoop. Thus, the loop pulls the main halyard forward from the mast toward the jib; by changing the diameter of the loop of line, you move the angle that the halyard is pulling the windscoop up from.
- Andy
Post by K9Kampers »
Andy asks:
Wo ist Monica?
Wie oft machen Sie fahren nach Boca Chica Beach? Haben Sie genießen die Vegetation und die Tierwelt, wie Sie durch Monica? Wo ist Monica? Monica war nie! :|
