Launching was uneventful and after clearing the dock area I set the Raymarine SPX5 autopilot to take us out through the harbour heads, which it did with no problem. Shortly thereafter, I used the pilot to alter course 20 degrees to starboard so as to take us out to clear the other breakwaters, then went below for a couple of minutes.
When I came up I found we were veering significantly off course to starboard and continuing to turn in that direction. I pressed Standby, manually adjusted our course then re-engaged the autopilot. It was fine for a few minutes then again started veering off to starboard. This time after I pressed Standby I checked the autopilot compass heading. It was showing significant and variable differences to the COG on the GPS - as much as 120 degrees out . In Auto mode, would not hold the set course for more than a minute or two and, when I tried to Track to a GPS waypoint, it likewise held the course for a while the again veered off to starboard.
I switched the Autopilot off and tried to enjoy the sailing for a few hours.
The harbour was almost deserted when we returned so I had enough still-water sea room to swing the compass and try to re-calibrate the autopilot. No luck! The display kept reading 'Turn Boat' and never came back with a Deviation reading.
Raymarine were responsive when I called and, after eliminating the obvious like a ferrous object being placed near the Fluxgate compass, thought that the problem might lie in the compass itself. They are sending a Technician out for some sea trials this Friday, and I will keep you posted on the outcome.
Meanwhile the moral of the story for me is that while autopilots are great, they can fail without warning so don't trust them for more than a minute or two...
