Loose lugs
Have you ever had your lug nuts come loose after you are sure they were tightened properly?
I use anti-sieze compound and I have never had problems with lug nuts coming loose
7
25%
I do not use anti-sieze compound and I have never had problems with lug nuts coming loose
15
54%
I use anti-sieze compound and I have had problems with lug nuts coming loose
0
No votes
I do not use anti-sieze compound and I have had problems with lug nuts coming loose
4
14%
I have had lug nuts come loose but I'm not sure if they were tightened properly to begin with
2
7%
Total votes: 28
Dimitri-2000X-Tampa
Loose lugs
Post by Dimitri-2000X-Tampa »
This should be an interesting poll and I appreciate your input.
Sloop John B
Post by Sloop John B »
My lug nuts deteriorate so badly in salt water I find it a several hour chore to remove them from one tire. This in spite of having coated them generously with no seize. I'll continue to do so, replacing the lug nuts (some went 'round' on me) and using a torque wrench for approximately 85 lbs.
Jack O'Brien
Anti-rust Lug Nuts
Post by Jack O'Brien »
Buy some stainless steel lug nuts. Use anti-seize lubricant and do not overtighten to prevent galling.
Dimitri-2000X-Tampa
If you hit the lugs with a bit of WD40 or stronger every few months, they'll stay new a lot longer.
