I have a Load Rite trailer with Tiedown Engineering Eliminator torsion single axle. Anyone on this forum using this type of axle? Many different trailer manufacturers use Tiedown's torsion axle.
I am wondering when you can tell if the axle needs replacing because of rubber cord fatigue.
Here are my pics of the torsion axle.
Tiedown Engineering torsion axle question
- MSS
- Location: Europe / Sweden 2002X - Honda 50EFI - MACX4868B202
Re: Tiedown Engineering torsion axle question
I have an AL-KO Kober type of shaft and yes, it needs replacing rubber cord. After 20-30 years or so my dealer told me.
Clever design. If you are in a climate like mine where you lay your boat up for 6 months, you could jack/prop the trailer up for winter and extend that life by 2x I bet.
In any event, 20 years is forever in trailer life. I guess you could watch to make sure the tires arent hitting the boat when you trailer. Even if it sags a bit, you can adjust the torsion arms to compensate I imagine
- opie
My boat has always ridden low, but I bought it used...
The ride is sweet though. Never any bouncing over a bump. Just the normal down and up and then stable, like a good shock absorber. And, no adjustments at all possible. I wonder as well if the cords could just slip around and leave my trailer on the ground. A Google search turned up no such issues... I guess I'll wait 20 years to replace it then.....
