First sail with Beene this yr
Well was up in Barrie on Sat spending more boat bucks @ W/M & gave Geoff a call so he invite me our for an afternoon sail which ended up into the evening :D 8)
http://s844.photobucket.com/albums/ab1/ ... 010059.flv
http://s844.photobucket.com/albums/ab1/ ... 010060.flv
so as the evening moved on the wind dropped from 10knts down to 4knts so Geoff decided to cheat a wee bit and powersail to get us back upto about 6knts then about 1/2hr later the wind dropped off completely so G decided it was time to drop the sails & fire up the big iron genny a few more rev's & said to me buy the way did I tell you my new 15" pitch prop works a charm I said no so just to show me how happy he was with it we cruised back in at about 22knts
http://s844.photobucket.com/albums/ab1/ ... 010062.flv
http://s844.photobucket.com/albums/ab1/ ... 010063.flv
Québec 1
Re: First sail with Beene this yr
Post by Québec 1 »
Geoff,
Thats a pretty fast looking white hulled boat. :o
Q1
Thanks guys :!: The Admiral and I enjoyed it.
Paul L
Post by Paul L »
Wow pretty impressive under power. Do you remember your RPMs at that speed? Was your ballast empty?
delevi
Post by delevi »
Very nice gentlemen. Looks like a good time was had by all.
That is one serious wake. Man, that's fast! Hey, "isn't that a sailboat? I'm sure you must be breaking some sort of law there..." :D :D
How much whisky consumed on the outing? :P
Is that a backstay I'm seeing?
Lazy jax... good mod
That rigid vang is a beautiful piece of equipment. Very nice.
I see you didn't spend much time flaking the main :P Tighten up that rigging too :P :o Seriously, tighten it up :D Ok. I'm not just kidding around. Tune the rig man. 8)
Glad to see you guys getting out there enjoying the lake.
cheers,
L.
Hi Leon
No speed limit , only when at the beach once inside the beach markers 5mp/h, approaching the harbour or marina 7mp/h
yes the wake is kinda cool :) :P
No whisky Kids on Board :)
No back stay just his old top lifting now used to fly the flag
lazy jacks yes but Lazy G has not finnished the mod yet & he talks about me !!
Rigid vang Yes they are Sweet :)
Yes I was jibbing him too about that loose standing rigging was sooo embarssing I hid in the cabin until we left the marina :D :D :D :D :P
Yep we always have a great time out on the lake :) 8)
Beene will have to kick-in and answer the rest of your questions 8)
For ease of search engine.
Posted snipit here
http://www.macgregorsailors.com/phpBB/v ... =9&t=16102
Had a great time J
Thanks for joining us.
Paul L
Post by Paul L »
26M
Merc 75 4s
Prop 13.75 x 15
Cruise rpm 3/4 throttle around 4000
Hovering around 22knts into light breeze
2 adults 2 kids aboard
Fins up
Ballast empty
I guess I need to upgrade my prop. Mine's a 13.75x13 (on a Suzuki 70) There is no way I come close to that speed, ballast empty at 4000 rpm (more like 10-12 knots!!)
Of course towing a dinghy doesn't help. Your video made it look real steady. I think I'd be spooked at the touchiness of it, esp with the mast up high center of gravity. And there you are, with one of you just wandering around the top deck at that speed. You are definitely more experienced and confident than I!
Paul
We have the big block Merc 75 f/s so lots of torq actualy my block is even bigger the geoff 's with fuel inj. :P
1732 CID block whats the size of your block !
Now now boys. Lets not start a p*ssing contest. You guys are old enough to be beyond a "mine is bigger than yours" razz. :D
Paul L
Post by Paul L »
I don't know off hand the CID of my Suzuki 70. Like yours, mine is a 4 stroke EFI.
I'm sure there is plenty of expertise out there about prop size options & trade-offs with the Suzuki 70. It's on my list of questions for the BWY crowd when we meet up in 2 weeks. There may even be a thread here on the subject.
Part of me would like to go as fast as your boat, but I'm not sure how comfortable I'd be at that speed with such a light, top heavy boat.
In any case, I'm more focused on trying to get the most sailing out of these light fickle winds of the Puget Sound & San Juans :(
I sure is different than the steady wind in San Diego where we took our ASA sailing course!
Paul
I checked out the block size for your eng . on the suzuki site only 1502 CID thats 230 CID less than my bigger block so I dout you can match the torq spec's
your gear ratio is 2.59:1
my gear ratio is 2.33:1
your eng weighs in @ 341#
my eng. weighs in @ 399#
No p"ssing contest here just trying to help , for our boats its not about HP you need the big block for torq. and the right gear ratio & you'll kick butt outa some one with more HP, smaller block & wrong gear ratio
J 8) :wink:
PS The proof is in the pudding as they say we just provided the video's to prove it :) 8)
Paul,
I'm sure Geoff is as concerned as you. You'll notice that his boat is going in a perfectly straight line on relatively smooth water.
Hi guys
The Mac M handles better at higher speeds then it does at lower ones.
Once on top, and I mean right up on top, not kinda sorta maybe ish..... , the Mac M handles great.
You will see in the video, later on, I make several turns, all the while the boat remains stable and on top.
With the M still in the hole, she handles poorly. Very unstable. Wants to wander. Bow dancing all over, hard to control and almost like it has a mind of its own.
All bad things.
Once you hit 20+ mph, she handles like a powerboat for the most part.
You will find you can handle corners with confidence.
Takes getting used to.
But she can handle great.
One thing to keep in mind is the balance.
With an empty ballast tank, she is sensitive to load shifting.
Keep that in mind at all times while powering at high speeds.
Weight on one side can and will lead to a turn that you were not expecting.
The boat will lean to the side the weight shifted to, and the hull contact with the water will cause enough drag to make the boat turn to that side.
I think the best prop for your Suzi 70 would be the 14x13 with transom wedges.
I believe BWY installs those on all 70's now.
Alex
Post by Alex »
I like custom made Cap " Highlander "
