Without any ballast, when one of my 200 lb+ boys would moved around on the boat, she would veer radically, so once we were out in some deep water, I stopped and filled the ballast. We motored around for a bit and then we stopped and deployed the anchor. We then fired her up again to see how fast we could get her to go with 850lb of crew and a full ballast, 9.5mph according to the GPS. Wish I had done a speed test before filling the ballast.
Soon I became more comfortable with steering the boat and we made it back to the slip, but not as graceful as we left (docking was normally not a problem in the other two boats.) First thing I’ll be installing is the “haul-down” lines (does anyone have a good diagram of the path and know the best way to thread the lines, once I open the holes?)
One of the reasons I took her out was to try and clean the engine out to get her to idle better. My plan was to use fresh gas and some SeaFoam, but West Marine didn’t carry it so I got some Sta-Bil Gas Stabilizer. I’ll think next I’ll still put in some SeaFoam and see if that helps and get some new plugs, any recommendations? I found these on Amazon; Bosch (4501) FGR8DQI Platinum IR Fusion Spark Plugs. Do the ethanol gasoline treatments help? I’d really like to put off rebuilding the carburetors till next winter if I can.
