This afternoon, after it stopped raining, I went out to work on getting the new cable in.
The 12' cable from UFlex is about 2" shorter than the factory Morse cable.
BTW, I looked at the original Morse cable in the boat and found a model number:
Morse 304411-144in
http://www.comstockcomputing.com/macgre ... 11645b.jpg
In hind sight, it seems obvious that the 144in means 144 inches...12'.
I pushed the new cable in from the back it took all of 3 minutes from starting it in the back to pulling it out on top. I didn't use the string that I so carefully pulled through. There was no need.
I used the bracket that came with the new helm. By installing it on the outside, facing in, it wound up with the wheel in (as far as I can tell) the same location.
http://www.comstockcomputing.com/macgre ... 111734.jpg
http://www.comstockcomputing.com/macgre ... 111744.jpg
I attached the bracket with the same bolts as the old bracket, in the same holes. I could have used the bolts that came with the new bracket...but I would have had to drill out the original holes to make them larger.
All I have to do now is hang the cable over the bunk.
