My service so far... pretty easy when you get a clue.
You can download the manual from my site:
http://www.ironengineer.com/mac/home/index.htm however I find it a little confusing.
An important item to change is the fuel pump. Now this is a rather flimsy little thing that sits on the bottom carb behind the oil tank, and relies on a diagpram and a couple of gaskets. I've heard of these splitting. The pump runs off the vacuum from the piston downstroke.. cunning really. Parts about $15, time 1hr.
Fuel filter is obvious enough, new plugs and I will look into new HT leads. On cars these ought to be changed every few years as they may look ok but break down internally and as soon as you have heavy damp / rain then the engine stops working. (the spark arcs out through the lead, or just loses the balls to do its' thing with the plug) It looks like the leads are of a push n screw in job like on motorbikes from the 80s. That will then be $2 and 20mins for great peace of mind.
Now.. the impeller. Dropping the leg is a doddle. I put the box in gear till I could see the coupling device. (fwd -rev??)This is simply a sleeve that sits on the shiny thin rod that goes from the top to the bottom at the front (or forward/bow facing ) part of the engine. It tapped out very easily with a backward drill, no special 'service tool ' required here. Then drop the six leg bolts and off it comes!
I can now see the impeller housing sat on the drive shaft. I guess I ought to just crack the thing apart and at a guess the top part would slide up the shaft and off, revealing old impeller
'Spose I'll have to try reading the manual
I'll take some photos and put together a service page together if I can get the time. Meanwhile, if anyone would like to confirm my pump splitting plan that would be most appreciated.
